Thread: 1200mmX900mmX170mm 4axis cnc
12-05-2018 #9
It is time consuming but stress relief!
I use the clear plexiglass to make the holes,this method is fast and accurate,no measurements to take and nothing can go wrong this way,you see thru the plexiglass where you must drill and just drill,freehand.
The you put the Plexi on the mdf or aluminum plate ,put both on the drill press and make your drills nice and square!
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
