Thread: 1200mmX900mmX170mm 4axis cnc
The Following User Says Thank You to Nr1madman For This Useful Post:
15-06-2018 #2
I was lucky with the motor mount ,I just too advantage of the one end of the heavy duty aluminum beam,it was made like that and I cut it with the grind cutter.
About the diagram I want some thing that will work and not burn any driver or something else,haha
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
