    Thanks Robert.
    I had the number one and number three schematic,thanks for the second one.
    Can I ask why you follow the first schematic?
    I was set on using the schematic from jazz since I started my build.
    Then I read the thread about the first I posted and thought it made sense..
    The one from routercnc has alot of extra benefits like bleed resistor and ability to change vfd speed manually.
    But I still went with the first :D
  2. The Following User Says Thank You to Nr1madman For This Useful Post:
  3. #2
    Just a casual observation for anyone looking to re-use these schematics.
    Some, probably not all, but certainly the cheap and nasty BoB that I have in front of me (and I've just re-tested) - which provide a 0-10V output to the spindle, and a 12-24V supply to provide this 10V reference on board... will use this same onboard 10V supply to drive the LED anodes on the opto-isolator inputs (so to switch the input, you connect the coupler's LED's cathodes to ground [via sensors, etc]).
    My point?, for these cheap BoBs, to use the inputs you still need to supply a 12-24V supply, as well as a 5V supply to the BoB.
    Like I said, probably won't apply to all BoBs.
  4. The Following User Says Thank You to Doddy For This Useful Post:
  5. #3
    Thanks everyone for the help and the very helpful info, it is time to make my study now... :-)
  6. #4
    The last two days we had temperature drop and some rain so I went to workshop and lift the gantry and push the x axis rails in the y axis bearings.
    I weighted the gantry out of curiosity and the scale show 32.5 kg with out the spindle and the aluminium plates at the place of mdf,I wonder if the two 4nm motors will be able to move the gantry and cut at acceptable speeds.:-(
    To lift the gantry I made some kind of a crane with some scrap metal beams I had in the shop.
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
