Thread: 1200mmX900mmX170mm 4axis cnc
17-11-2018 #2
17-11-2018 #3..Clive
17-11-2018 #4
Thanks guys!
Clive CY4 core for the motors and parallel wiring for the motor's coils right?
The Following User Says Thank You to Nickhofen For This Useful Post:
17-11-2018 #5
17-11-2018 #6
8 wires of course,I forgot to mention it
17-11-2018 #7
My layout is a mirror image of that because the VFD air inlet is on the left. I cut out a large hole in the side of the enclosure next to it to allow the air straight in to the VFD and the it exhausts out of a hole directly above it. That stops it drawing warm air from the enclosure.
I allowed 2 80mm fan sized holes in the base of the enclosure below the drivers but never added the fans as they barely get warm. Natural convection seems to work fine although we are in the UK so it does not get that hot.Last edited by routercnc; 17-11-2018 at 08:37 PM.
18-11-2018 #8
Thanks routercnc.
I have in mind to use two fans on the bottom of the enclosure box to push air in there and a filter for the dust and two on the top.
The info about the hole near VFD is very good,I am going to use it!
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
