Thread: 1200mmX900mmX170mm 4axis cnc
Hello !
I think you (or me) has misunderstood..
The bearings on x axis your long axis should be wider preferably so that the tip of the cutter is between them when viewing the machine from the side.
The y axis bearings on gantry can be closer.
If you use 90x90x4 steel with no welding, how will you close the ends to be able to bolt there?
02-08-2017 #2
How close can be the bearings on the gantry so I can have good accuracy and eliminate the tolerance when torgue applied on Z axis ?
The ends of the tubes is going to be welded with steel flanges, I prefer minimum welding for minimum stress and to be able to adjust- align everything.Last edited by Nickhofen; 02-08-2017 at 09:54 PM.
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
