Thread: 1200mmX900mmX170mm 4axis cnc
04-08-2017 #1..Clive
04-08-2017 #2
04-08-2017 #3
04-08-2017 #4
19-08-2017 #5
After some sleepless nights watching some video tutorials about Fusion 360 CliveS point me, thanks Clive, I came up with this.
The questions now are:
Can I use two pieces from this aluminum extrusion for the Y axis, not complete on the photo, and screw them them at left and right on the supports?
And what extrusions can I use for the X(long) axis, to support the Hiwin rails and screws.
http://www.ebay.co.uk/itm/like/17233...?ul_noapp=trueLast edited by Nickhofen; 01-09-2017 at 08:40 PM.
22-08-2017 #6
I was thinking the option of using aluminum extrusions for the axis, since this way there is no need for drilling ,tapping and leveling with epoxy!
22-08-2017 #7Yes use two pieces one flat and one upright like an L. Then drill the upright one down the channel slot and bolt it to the flat one with tee nuts M6 90mm cap headCan I use two pieces from this aluminum extrusion for the Y axis, not complete on the photo, and screw them them at left and right on the supports?..Clive
22-08-2017 #8
Thanks Clive, always so helpful!
Can I use the same extrusion for the x(long axis ) to bolt 20mm rails and ballscrew on? Or I need a thicker extrusion?
22-08-2017 #9
Its very nice using extrusion (heavy duty) because the slots it the 90x45 are exactly correct for the bk and bf bearings and can be mounted with tee nuts 6MM the 20mm rails will also mount into on top of the slots. You would have to work out how to fix the extrusion to your frame.
The ends of the extrusion can also be tapped without drilling for M12 bolts. with a spiral tap in an electric drill...Clive
23-08-2017 #10
Hmm I'm at this stage myself but I was thinking about drilling through the bottom extrusion and use tee nuts in the upper extrusion and cap head screws with washers to fill out the t slots. Then use the holes I drilled to tighten the screws. What do you all say about that?
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
