Thread: 1200mmX900mmX170mm 4axis cnc
25-11-2017 #11
Okey.. but do you want one for each motor and separate for switches or do you want only one big cable?
If bundling several signals in the same cable you loose the screen protection between them..
The normal that I see people using is one for limits and a one each for each motor
And of course if you want e-stop on the machine or probe or something like that.
Steppers are usually 4 signals + shield so 5 pins.
A switch depends on type of switch! But could be +, gnd, signal, shield so total 4 pins.
But it could also be + and gnd without shield for a simple mechanical switch with simpler wire for a total of 2 pins. But greater risk of interference.
So it all depends on your equipment :)
The Following User Says Thank You to Nr1madman For This Useful Post:
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
