Thread: Milling styrofoam board enquiry
	05-05-2017 #1
Howdy,
I'm just running some test milling forms in blue styrofoam board. I am making lost foam masters for aluminium casting.
I'm running cut tests on a low relief model (150mmx150mmx40mm). I'm using a 8mm OD rasp bit to rough out and using a 2mm OD end mill to finish. I run both at a feed rate of about 2 cm/sec but the spindle on its slowest RPM (approx 11000rpm). This combination seems to give me the best results.
However I see that the final finish is still quite hairy and the rasp sometimes still gets too hot/ and or melts the styrene. Are there some know techniques or bits for working with styrene I should try? I think i'm pretty close but just wondering if there is anything I can tweak.
ThanksLast edited by marbles; 05-05-2017 at 06:05 PM.
	10-06-2017 #2
I use downcutters with some success on blue Styrofoam. Both in 8mm and 2mm. But lately broke the 2mm on another job and looking for a re-source should you find one?
The finish was marginally better and surface stringing much better. Not to the same degree as wood downcutting, as you might expect. But for me better!
The Following User Says Thank You to Leadhead For This Useful Post:
	11-06-2017 #3
Thanks. I bought a couple of 4 flute upcutters recently but your right I should try a new sharp downcutter to compare. Looking at the endmills specifically sold for polystyrene and foams lots of them are upcutters but what i am adviced is to run these bits below 6000rpm so just about to see how my spindle, which currently has a minimum of 12,000rpm likes running at half that.
	11-06-2017 #4
Try doubling your feedrate.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
	13-06-2017 #5
The Following User Says Thank You to cropwell For This Useful Post:
Problem milling extruded polystyrene (Styrofoam) solutions requested.
By marbles in forum General DiscussionReplies: 1Last Post: 23-08-2015, 12:39 PM -
oracal 813 Blue Paint Mask ??
By amxen in forum Wood Finishing Tips & TricksReplies: 1Last Post: 18-01-2015, 10:43 PM -
Layout Blue
By GTJim in forum Marketplace DiscussionReplies: 4Last Post: 09-07-2012, 10:02 PM
