    I have for sale a couple of things in the Leicester Area, I also might swap for CNC items. P&P is extra to price shown and will be done at cost or you are welcome to organise some items are very heavy. Collection is fine and normally I can do 7 days a week with notice. Near J.21 M1
    1. 2nd hand Nema 34 5 wire, with cog attached I can also supply a matching cog (With grub screw attachment) or I can remove the cog with a hydraulic press if required. I will test motor tomorrow but it turns freely and has significant resistance when you connect the right wires together. Also the machine worked 2 months ago.
    For perspective I have put a Nema 23 next to it That is NOT FOR SALE!
    £60
    I will add measurements tomorrow not sure the amps but this is a long one and heavy one.
    2. Axis table 25mm rod (Might be 30mm) and looks like lead screw drive, no bearings so do not use this for a Z! I'm using one for a single axis on my drill press.
    £50+P&P (Heavy 10kg+) will weigh tomorrow
    3. Ballscrew assembly this is very chunky pretty certain it's got a ground ballscrew in it, minor surface rust on the smooth rod, ballscrew is mint. Turns so smoothly it's lovely! This is ideal for z axis conversion and I'm keeping one of thes for exactly that! 25mm smooth rod and 20mm ballscrew with bearings, ballnut & end bearings for the ballnut.
    £100
    comes with stepper motor (8 wire) I couldn't get it to work but didn't try that hard lol, turn ok. Motor is very small but I'm sure there was a good reason they used it so might be worth something. I've took it off but you're welcome to it and mounting bracket.
    This is very heavy collection is preffered 20-30kg will weigh tomorrow.
    What I want
    2 Nema 23 a matched pair 2-3 amp range
    Not essential to my build but always open to linear slides/rails/guides but 1.5m or above only
    Spindle with mounts.
    If you are in Leicester Area have a cnc machine/milling machine that can make my mounting plates for the axis, including the z axis and help me assemble this then I'm very open to a deal and I have a fair more things you might be interested in.
  1. FOR SALE: For Sale: Unimatic 3 Axis Table & Controller
    By MarkT in forum Items For Sale
    Last Post: 08-10-2019, 02:51 PM
  2. RFQ: Ballscrew bearings repacking help
    By Maravedis in forum Projects, Jobs & Requests
    Last Post: 04-04-2016, 01:01 PM
  3. bearings and ballscrew dont fit each other
    By marbles in forum Lead Screws, Nuts & Supports
    Last Post: 09-02-2013, 06:06 PM
  4. Boxford TLC 125 ballscrew bearings
    By lamestllama in forum Boxford Lathes
    Last Post: 25-03-2011, 05:57 PM
  5. Ballscrew Support Bearings - Angular or Self Align or ??
    By williamturner1 in forum Lead Screws, Nuts & Supports
    Last Post: 02-10-2010, 02:38 PM
