Page 2 of 2 FirstFirst 12
    Here you go.
    A plug in to go from Sketchup directly into Cambam.
    http://www.cerebralmeltdown.com/cncs...cambam_export/
    John S -
    Now there's something I didn't know about!
    CAMBAM ... I guess it is free .. I don't see anything on their site with prices or ought.
    I'll give that a go for sure:exclaim:
    Well done John, :clap: have you used it yourself?
    John
    Templecorran
    Where the Light was kept during the Dark Ages
    FredPena's Avatar
    Location unknown. FredPena Last Activity: Has a total post count of n/a. Referred 6715 members to the community.
    U might want to check out the Phlatscript, a plugin designed to workup & export gcode from sketchup, made for the Phlatprinter, a cnc machine designed to cut foam for model aircraft, but may work for u as well.
    Fred
    Phlatforum
    Try SketchuCam they have good truing videos and identify how to push your file to G code.
  5. #15
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    V-Carve Pro and Aspire can now import Sketchup files and create toolpaths from them.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  6. #16
    Thank you, there are also some good Extensions available from Phatboyz that generate Gcode
  7. #17
    Quote Originally Posted by templecorran View Post
    I wanted to stress that Sketchup is a wonderful Proof of Concept tool. Not recommended for model manufacture.
    It does seem a problem that such I popular and easy 3D tool would be so troublesome to CNC. Trimble should sort out this mess.
    Zymon
  1. RFQ: 8 off steel plates required, drawings attached
    By TonyD in forum Projects, Jobs & Requests
    Last Post: 10-05-2014, 10:26 PM
  2. Working / Diagnostic drawings
    Last Post: 04-09-2013, 12:57 PM
  3. Cross sectional dimensions for CAD drawings
    By Husky in forum Gantry/Router Machines & Building
    Last Post: 24-02-2013, 06:19 PM
  4. Examples Heidenhain programs with drawings
    By hoezap in forum Computer Software
    Last Post: 09-02-2013, 12:54 AM
  5. how to convert a mill to cnc?
    By speedhound in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2010, 09:07 PM
