Thread: Help me choose my first spindle
That's the one I have
Something like this is good
https://www.ebay.co.uk/itm/80-100mm-...QXW0C2j_rVrnVg
Mine took about 10 working days to arrive.
If you wire it to the BOB to control speed and turn on/off then there's not a lot to setup on the VFD I haven't done this yet so control the speed from the VFD but it makes more sense to wire it to the BOB.
The manual is confusing but there's a great thread on cnczone about how to use the vfd and all the info you need is in the manual just in Chinglish.Last edited by Desertboy; 03-05-2018 at 10:50 AM.
03-05-2018 #2
Thanks - bracket ordered from ebay (There's many sources of 80mm bracket on ebay I now realise)
This is the in-forum set-up article I was originally looking for.
Just need the spindle to arrive now.
Now onto appropriate collet sets ...
03-05-2018 #3
Could someone recommend a cost-effective ER20 collect set appropriate for a Chinese spindle.
Had a look on the Internet but I'm confused about the vast range in prices and therefore don't know how to choose an appropriate set. In shorty, I don't know how to grade/judge ER collects.
Thanks.
04-05-2018 #4
I can't recommand any specific seller but eBay is full of ER20.
https://www.ebay.com/sch/i.html?_fro...t+set&_sacat=0
BTW, I bought my spindle from the same seller as you did. After about two years it is still working well. Just make sure you connect the earth because the spindle is not earthed. Mine is just a 1.5kW air cooled, but I am still happy with it.
04-05-2018 #5
I bought this one
https://www.ebay.co.uk/itm/10-13PCS-...dVQzQLIz2sfBfQ
No complaints for £20http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-05-2018 #6
You can also fit a pot on the front panel to control the speed http://www.mycncuk.com/threads/7388-...se-Spindle-VFD
Help me choose a mill.
By Fingerpuk in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 25-11-2016, 12:41 AM -
Which CNC Router to choose, and what are the costs
By Painted Letters in forum Machine DiscussionReplies: 5Last Post: 29-06-2016, 03:54 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
HELP:How to choose
By sinograver in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 17-10-2011, 02:00 AM -
How to choose a lead scew
By GTJim in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 15-02-2009, 12:30 PM
