Thread: Help me choose my first spindle
Hi Boyan,
I've read a lot of your posts and seen some of your builds and so I know I would be wise to listen to your advice.
I try not buy things if possible lol the z axis will be made with this
(Once I have it rebuilt) I have 25mm smooth rod with bearings as well.
which cost me 1 days very hard work stripping it out a machine (I got 3 of them) but no actual money just hard work ;)
I'm using 25mm supported rail on 1 axis because I got it for free and 15mm hi win on the other axis because 1.5m with 4 blocks on 2 rails was £99 delivered.
This is a cheap hack machine lol but I do intend to pimp it up or just build another one I have more t slot and sometimes I get get rails to scrap ;) so we will see.Last edited by Desertboy; 14-05-2017 at 01:08 AM.
16-05-2017 #2
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
16-05-2017 #3
Too true
https://www.aliexpress.com/item/Hig-...796651547.html
looking at this on alixpress when I build another one (I want 8*4 capability) I think I should just use these all round at this sort of price unless I'm particularly lucky with the next machine that comes in.
I was thinking the best thing to do with the supported rail is to use it until it becomes an issue then keep the rail and bearings for a table saw slide to make cutting 8*4 a joy.
Although I want at least one axis to have 3m rails.
So going to cost a £1000 by the time the import tax man has his fingers in the tills lol.1Last edited by Desertboy; 16-05-2017 at 06:50 AM.
16-05-2017 #4
02-03-2018 #5
So I wish to upgrade from my Kress motor and I'm wondering if the spindle that started this thread is the way to go?
Advice please.
Karl
02-03-2018 #6
That's the one if your machine can carry it. https://www.ebay.co.uk/itm/2-2KW-WAT...c=1&rmvSB=true
02-05-2018 #7
OK, rightly or wrongly I've just ordered one of these spindles from Germany.
So now I need to:
- Source a bracket - recommendations please -?
- Learn how to configure and operate the spindle - I'm sure there's an article or 2 on this site somewhere - ?
- Absorb recommendations etc from folks who have such a device - ?
Hoping folks can point me in the right direction.
Karl
03-05-2018 #8
That's the one I have
Something like this is good
https://www.ebay.co.uk/itm/80-100mm-...QXW0C2j_rVrnVg
Mine took about 10 working days to arrive.
If you wire it to the BOB to control speed and turn on/off then there's not a lot to setup on the VFD I haven't done this yet so control the speed from the VFD but it makes more sense to wire it to the BOB.
The manual is confusing but there's a great thread on cnczone about how to use the vfd and all the info you need is in the manual just in Chinglish.Last edited by Desertboy; 03-05-2018 at 10:50 AM.
03-05-2018 #9
Thanks - bracket ordered from ebay (There's many sources of 80mm bracket on ebay I now realise)
This is the in-forum set-up article I was originally looking for.
Just need the spindle to arrive now.
Now onto appropriate collet sets ...
Help me choose a mill.
By Fingerpuk in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 25-11-2016, 12:41 AM -
Which CNC Router to choose, and what are the costs
By Painted Letters in forum Machine DiscussionReplies: 5Last Post: 29-06-2016, 03:54 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
HELP:How to choose
By sinograver in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 17-10-2011, 02:00 AM -
How to choose a lead scew
By GTJim in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 15-02-2009, 12:30 PM
