Thread: CNC drill bit conundrum...
06-07-2015 #2
Wow, that was an old post.....in the end I found a good Uk source for drill sizes larger than 3.175mm (but with a 3.175mm shaft), here you go...
http://www.acsind.co.uk/ ...I was dealing with - Dave Cornell (Technical Sales Engineer)...I don't want to post his email on an open forum (else bots will start spamming him), but if you want to email him direct, shoot me a PM)
...they do both new & re-pointed, being a tightwad, I bought re-pointed (but frankly I got great results with them & couldn't tell the difference vs. brand new), they have all manner of sizes available & the prices were excellent as were their postage charges (no affiliation!). I mainly bought sizes below 3.175mm as the cost does go up somewhat for sizes greater than 3.175mm...but I did order a spattering of larger sizes (e.g. 4.0mm 4.2mm 5.00mm 6.0mm & 6.35mm) all with 3.175mm shafts....a great time saver when you're only drilling acrylic.
Edit: I've just found the email with the prices I paid back in 2011 (just to give you an idea)...
10 off Repointed 1.60mm drills @ £4.49 in total (i.e. 44.9p each)
10 off Repointed 3.00mm drills @ £4.49 in total
10 off Repointed 3.175mm drills @ £4.49 in total
2 off Repointed 3.40mm drills @ £4.36 in total
2 off Repointed 3.60mm drills @ £5.14 in total
2 off Repointed 3.80mm drills @ £5.14 in total
2 off Repointed 4.00mm drills @ £5.14 in total
2 off Repointed 4.50mm drills @ £5.90 in total
2 off Repointed 4.80mm drills @ £6.68 in total
2 off Repointed 5.00mm drills @ £6.68 in total
2 off Repointed 5.50mm drills @ £7.56 in total
2 off Repointed 6.00mm drills @ £8.36 in total
2 off Repointed 6.35mm drills @ £9.00 in totalLast edited by HankMcSpank; 06-07-2015 at 12:00 PM.
06-07-2015 #3
That's brilliant thanks, it will save a lot of time ! Much appreciated.
06-07-2015 #4
Can't you just cut 4.2mm pockets, or do you need to go to great depth ?
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
Stumpy 3.5mm drill bit?
By craigrobbo in forum Tool & Tooling TechnologyReplies: 8Last Post: 09-04-2013, 01:33 AM -
pillar drill?
By wilfy in forum Machine DiscussionReplies: 22Last Post: 10-11-2012, 09:18 PM -
best drill bits
By oadamo in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-01-2011, 11:25 PM -
Dowel Pin Drill jig
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:34 AM
