  1. #6
    Good luck with your build, I'm no expert but looking at your cad models 2 things springs to mind.
Name:	router build 1.png
    I am going to do things differently to you and not have the 4 corner plates, instead I'm going to bolt the supported rail to the sides of the extrusion and the ballscrew to the top and have vertical plate mounts.Click image for larger version.
    Of course the disadvantage of mine is it's direct drive via couplings.
    A little late now but KJN offer a drilling service as well so you can do away with the corners and bolt through the extrusion I'm going to have mine drilled AND use the corners.
  1. NEW MEMBER: Looking to build a CNC router
    By ContentTooShortError in forum New Member Introductions
    Last Post: 26-10-2016, 05:05 PM
  2. Router build
    Last Post: 18-12-2014, 07:19 PM
  3. RFQ: Does anyone want to build me a cnc router?
    By totally useless in forum Projects, Jobs & Requests
    Last Post: 08-05-2014, 09:55 PM
  4. Does anyone want to build me a cnc router?
  5. BUILD LOG: A3 Router Build
