Thread: Router Build Mk 1
17-05-2017 #8
Hi Desertboy,
Thanks for the comments. I did think about placing the supported rails on the side of the extrusion. The one reason that I didn't was because of the tolerances of the cutting of the aluminium profile for the Y axis. KJN quote, I think a tolerance of 0 to +2 mm. Which I thought if this was the worst case and was 2 mm over I would need to use shims. Whereas bolting to the top of the extrusion gives me a certain amount of wiggle room with the bolts in the slots to remove this tolerance if required. I'm not sure if that is best practice, it just seemed to make sense at the time I ordered the profile.
I did also consider direct driving the ballscrews. In hindsight the best thing I could have done is got 1610 instead of 1605 ballscrews and then I would have had speed as well as torque by direct driving them, but at the time of designing I think I was more interested in the speed and hadn't really considered the potential backlash issues. I could I suppose easily convert to direct drive later if backlash becomes an issue.
CheersLast edited by hoppo; 17-05-2017 at 09:02 PM.
The Following User Says Thank You to hoppo For This Useful Post:
NEW MEMBER: Looking to build a CNC router
By ContentTooShortError in forum New Member IntroductionsReplies: 2Last Post: 26-10-2016, 05:05 PM -
Router build
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 39Last Post: 18-12-2014, 07:19 PM -
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
