Page 1 of 3 123 LastLast
    Could anyone recommend a "Simple 3D Gear design software" please. Would like to generate and machine a couple of bevel gears for 90deg transmission. Not for a strenuous operation, just a mechanical lifter. Looked at Gearotic but that is way over the top. Hopefully open source programme is available.
    Any advise appreciated.
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    There's nothing simple about gear design, especially once you get more complicated than a basic spur gear.
    Best option would be to find somebody with a copy of gearotic who's willing to produce the code you need, or just buy a couple ready made gears.
    m-c - Not completely unfamiliar with relatively simple gear design. Just do not want to revise and re-teach myself at this time.
    But would like to experiment with a couple of things. This would totally frustrate any third party!
    The bevel gear add-in for F360 produces what I want but it is a trade off between graphic presentation and real gear form. But studying this to see if it will suffice in this instance. I need to cut with a vertical axis and radial toolpath, so will not be generically correct in any case. But I will will cut a pair and see. Maybe try printing the same in nylon on a metal core.
    Quote Originally Posted by Leadhead View Post
    Could you not just buy the gears off the shelf? They are not that expensive from the likes of beltingonline?
    https://emvioeng.com
    George - That`s not the spirit of it?? - Jigsaw mentality - more fun to do it, than what you end up with.
    Any decent CAD software has a polar array function, meaning you only need draw one tooth. also it should be possible to get a tooth cross section from somewhere (I haven't looked but feel confident)
    I think you'd get away with a standard tooth profile, tilted so it matches the correct cone angle.
    I'd have to dig out the gear design/machining book I've got buried somewhere to confirm that though.
    Trouble is, tooth needs to scale with distance along - tooth width and gap aren't constant. There are some standard ways of getting close using a dividing head and taking three cuts per tooth space but I'm not sure how you would fully automate that.
    For clarity, I am aiming at a full 3D file to cut conventionally on a 3 axis CNC. With the axis vertical and if practical a radial toolpath.
    I believe I am almost there with a bit of caddery-pokery. Makes one very respectful of Art Fernety and his Gearotic software.
    Out of interest, what kind of size/tooth count are you looking at? Tool choice would be interesting as well - small enough to get into the bottom of the tooth but still giving a decent finish?
  1. CNC Design and Mach3 Training Courses - Simple CNC Ltd
    By simplecnc in forum Manufacturer News
    Last Post: 02-07-2019, 07:57 AM
  2. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  3. Replies: 2
  4. Design software
    By Andrew Hay in forum CAD & CAM Software
    Last Post: 10-06-2012, 10:40 AM
  5. My first gear, a deadbeat escapement gear for my clock
    By clockman in forum Woodworking Project Showcase
    Last Post: 30-01-2011, 11:39 PM
