Thread: epoxy question
    - Simple seperation from scaled steel surface.
    - Simple seperation from grinded steel surface.
    So ... I need to be carefull when removing unwanted material.
    Did any of you prime the steel with a coating to prevent easy seperation?
    Did you make sure that the surfaces were clean and free of any oil deposits. I have used the West system with no issues and the epoxy bonds well to the steel.
  2. Quote Originally Posted by Clive S View Post
    I also used West System, ground back the surface a little and it was fine. Make sure you have the ratio correct and mix mix mix!
    well made sure... degreased with brake cleaner.. wipedown and brake cleaner 2 times before grinding...
    maybe use paint thinner or amonia or something else...
    the test was done with 20gr resin + 8 gr hardner.... bigger volume will give me better resolution (1gr precision scale )
  4. Quote Originally Posted by driftspin View Post
    To be honest I never tried it with such small quants just went straight for the big pour! But it worked fine.
    http://www.mycncuk.com/threads/4513-...9752#post79752
  1. Self levelling epoxy resin
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 21-11-2020, 01:47 AM
  2. Use of epoxy for levelling
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-08-2019, 04:21 PM
  3. Self levelling epoxy
    By samsagaz in forum Gantry/Router Machines & Building
    Last Post: 07-05-2016, 12:40 AM
  4. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
  5. Epoxy pouring advice
    By cncJim in forum General Discussion
    Last Post: 18-02-2014, 05:25 PM
