Thread: Servo Overheat
  1. #7
    Lives in Plymouth, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    I'm not an expert in this area, and I only have limited experience based on my own machine, so please take that into account in whatever I say here! However, I have spent some time kicking around figures for my machine, so these numbers aren't just plucked out of the air.
    First - microstepping. You currently have 10/3200 mm = 3um resolution. I'm using 5mm pitch with 1600 usteps, giving the same resolution. This is way better resolution than is needed (for woodworking, at least) and probably better than the backlash in your ballscrews, unless you are using rather better quality screws than most of us! I use x8 microstepping as a balance between torque and smoothness; it seems to be generally accepted that this is a good target figure as higher microstep ratios (such as you are using) cause torque to fall off; lower ratios give a rougher drive. I once played with a machine with no microstepping configured and it sounded like marbles in a cement mixer. I reconfigured to x8 and it was much, much better. I suspect that if you go to 1600 ustep/rev you might get better torque and so less chance of stalling.
    My gantry weighs, at a guess (never weighed it, but I know what it felt like lifting it on and off while building the machine, and then it has the Z axis assembly and spindle motor added) around 60kg. That is driven by two 3Nm NEMA 23 steppers so roughly speaking each motor is driving about the same mass as your motor. You appear to be using nominal 1.9Nm motors, so they are a bit down in torque compared with mine. At the same time, you are running at about twice the speed (my rapid max is 4500mm/min as I get stalling problems above this) so have more drag from guide rails (although I realise that your problems do not happen at higher speeds so this is probably not too relevant) but also using around twice the acceleration figure. My machine runs with acceleration set to 600 (whatever units that is in). According to the little graph in the Mach3 config page, that gives 0-full speed in about 0.15s. You are trying to accelerate at twice this rate, with higher pitch ballscrews which means twice the torque required, with lower torque motors. Someone might well argue that my machine is conservatively configured and they might be right, but I do a fair bit of fine 3D machining and I worry as much as anything about things like pulley-ballscrew fixings handling this amount of torque with a lot of axis reversals and coming loose.
    Your other axis (we have different conventions re X and Y!) has similar loads, but lower speed and acceleration. Is there a reason for this? Based on testing, gut feel, or inspired guesswork? (I used the last of these with a bit of testing to confirm, BTW...)
    Given that this is an intermittent problem, that seems to come after a period of running, and tends to happen at low rather than high speeds (which is actually the higher average current situation for the steppers) I would still be chasing something like thermal shutdown in the driver, unlikely though this seems. Other possibilities are noise (but why only after a significant period of running and only one axis?) and something odd on the Mach3 PC causing the pulse stream to glitch (but again, why one axis and only after running for a time?)
    Have you been able to try swapping drivers from one axis to the other and see if the problem follows the driver or not?
    I suspect that you have already gone through much of this thinking, and I put it forward less as a probable diagnosis and more in the hope that as you say to yourself, "this guy's talking nonsense - but maybe if I check..." you might get a blinding flash of inspiration! I hope so - good luck with it.
  1. FOR SALE: JMC servo kit for sal
    By remrendes in forum Items For Sale
    Last Post: 24-04-2020, 12:14 PM
  2. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
  3. help with servo motors Please.
    By ramsbury in forum Stepper & Servo Motors
    Last Post: 18-02-2014, 04:59 PM
  4. Dc servo driver
    By Treemonkey in forum Motor Drivers & Controllers
    Last Post: 11-02-2013, 08:16 PM
  5. re servo encoder
    By Scott in forum General Electronics
    Last Post: 24-06-2010, 08:30 AM
