Thread: Y axis problem
    Hi thanks for your reply, what do you mean by the rising edge of the signal? If I reinstall mach3 will that affect my license
    Quote Originally Posted by Kev2960 View Post
    What is your stepper driver exact name and model? Normally there is a jumper on the driver / controller to change that. Also is explained in controller user manual. Normally mistake is seen on the z axis as it makes more movements, if all is not set right. Check it anyway.
    No. The Mach3 license file is called Mach1Lic.dat , so just go into Mach3 folder , find the file and save it somewhere else. If you don't have original manufacturers Set file open Mach3 and take snapshots of "general " , " motor tuning"/for each axis/ , "inputs outputs" , "homing limits" setting tabs. Uninstall mach3. Delete folder mach3. Restart. Install Mach3. Restart. program all setting. SAVE SETTINGS. CLOSE MACH3. Open mach3 and check how all is working. Once you are happy and all works well make a copy of your screen for further use, so you dont have to input every detail again and again.
    Close mach3 when its doing something, power down the PC without closing Mach3 and its f%%$d up 101%. Did i tell again how much i dislike it for that little details and behaviour...
    Thanks Clive
  1. Z axis problem
    By Kev2960 in forum Chinese Machines
    Last Post: 19-02-2017, 10:09 PM
  2. Help with Problem X axis Stepper Please
    By howser37 in forum Gantry/Router Machines & Building
    Last Post: 09-02-2017, 06:31 PM
  3. Problem with my Z axis
    By mikem in forum Stepper & Servo Motors
    Last Post: 03-11-2015, 11:52 PM
  4. Redsail laser engraver x axis problem
    By sthdklen in forum Laser Machines & Building
    Last Post: 21-03-2015, 03:44 PM
  5. z axis problem on rye ma 1500 with a bosch cc100
    By rickybabe in forum Rye CNC Routers
    Last Post: 28-04-2010, 09:04 AM
