Thread: Y axis problem
14-09-2017 #32
What is your stepper driver exact name and model? Normally there is a jumper on the driver / controller to change that. Also is explained in controller user manual. Normally mistake is seen on the z axis as it makes more movements, if all is not set right. Check it anyway.
No. The Mach3 license file is called Mach1Lic.dat , so just go into Mach3 folder , find the file and save it somewhere else. If you don't have original manufacturers Set file open Mach3 and take snapshots of "general " , " motor tuning"/for each axis/ , "inputs outputs" , "homing limits" setting tabs. Uninstall mach3. Delete folder mach3. Restart. Install Mach3. Restart. program all setting. SAVE SETTINGS. CLOSE MACH3. Open mach3 and check how all is working. Once you are happy and all works well make a copy of your screen for further use, so you dont have to input every detail again and again.
Close mach3 when its doing something, power down the PC without closing Mach3 and its f%%$d up 101%. Did i tell again how much i dislike it for that little details and behaviour...Last edited by Boyan Silyavski; 14-09-2017 at 12:02 PM.
Z axis problem
By Kev2960 in forum Chinese MachinesReplies: 12Last Post: 19-02-2017, 10:09 PM -
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Problem with my Z axis
By mikem in forum Stepper & Servo MotorsReplies: 4Last Post: 03-11-2015, 11:52 PM -
Redsail laser engraver x axis problem
By sthdklen in forum Laser Machines & BuildingReplies: 4Last Post: 21-03-2015, 03:44 PM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM
