Thread: Y axis problem
    Quote Originally Posted by Kev2960 View Post
    Hi Robin as you suggested mark the motor shaft do a cut return to start position. the motor shaft is about 1/8th of a turn out of position when cutting a circle 40mm dia
    There you go then loctite the pulley or coupling on then
    Edit. My bad I thought he meant shaft had moved in the coupling
    If the motor shaft is out of position at the end, doesn't this sound more like an electrical problem?
    1/8 turn is about 0.6mm error - is that about right?
    I think you said 320 steps per mm, which would be x8 microstepping with a 5mm lead ballscrew - sounds about right. So, 1600 steps per rev. 1/8 turn is 200 steps - that's a lot! Does this happen with air cutting? If so, can you slow the max speed and acceleration right down to remove the chance of it being missed steps? Is the error always exactly the same each time you test it, or does it vary quite a lot? Does it happen with the spindle running and spindle stopped?
    Out of curiosity, where does the gcode come from? As I mentioned earlier, I had a similar problem when I first started setting up my own router, although in my case the error was much smaller (although still cumulative) and I'm trying to think through a logical sequence to try to narrow down the problem.
  1. Z axis problem
    By Kev2960 in forum Chinese Machines
    Last Post: 19-02-2017, 10:09 PM
  2. Help with Problem X axis Stepper Please
    By howser37 in forum Gantry/Router Machines & Building
    Last Post: 09-02-2017, 06:31 PM
  3. Problem with my Z axis
    By mikem in forum Stepper & Servo Motors
    Last Post: 03-11-2015, 11:52 PM
  4. Redsail laser engraver x axis problem
    By sthdklen in forum Laser Machines & Building
    Last Post: 21-03-2015, 03:44 PM
  5. z axis problem on rye ma 1500 with a bosch cc100
    By rickybabe in forum Rye CNC Routers
    Last Post: 28-04-2010, 09:04 AM
