  1. #3
    Toolman there is also quite a few sticky threads in the Stepper and Servo forum if you would like a better understanding and some more reading.
    Link: http://www.mycncuk.com/forums/80-Stepper-Servo-Motors
    As said above, you typically cant go wrong for most machines by using Nema23's in the 3Nm flavour, basically try and find the versions with the lowest inductance and the cheapest price, right now that is the ones from CNC4YOU listed here:
    Link: https://www.cnc4you.co.uk/Stepper-Motor/Nema23-3.1Nm
    3 of these with p&p is still the better option than going via China and importing some, they continue to hold their price well at our purchase level.
    Edit: Lee, the way you can increase the rapids is to use higher voltage drivers, look at units like the EM806 or the AM882, using software you can fine tune these drives once fitted as they are digital.
    Good Luck!
  2. The Following User Says Thank You to Lee Roberts For This Useful Post:
  1. Replacement motor choice for SEM servos on a Harrison M300 lathe
    By PeteL in forum Stepper & Servo Motors
    Last Post: 03-05-2016, 07:05 PM
  2. VFD choice
    By D-man in forum Spindles & Drive Motors
    Last Post: 20-02-2016, 03:38 PM
  3. CNC router choice out there.
    By CTJ in forum Machine Discussion
    Last Post: 10-12-2015, 09:51 PM
  4. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 08:38 PM
  5. Help Make 1st Step - Wiring Up Drivers to Motor and Arduino
    By Treemonkey in forum General Electronics
    Last Post: 25-04-2013, 05:47 PM
