  1. Hello CNC users!
    I am looking for some advice on purchasing a 3 axis CNC router for business use.
    I am a musical instrument maker running a small business. I used to be a professional model maker and in that industry used a 3 axis cnc router regularly. Here is an image of what I make. Basically its a small type of accordion called a concertina:
    I always used to use the "laserscript 6090" in the model making industry, see the spec here:
    http://hpclaser.co.uk/index.php?main...products_id=50
    In my opinion this is a great router and it would be perfect for reducing production times by making components and jigs. I would be very happy to simply own this one except it is a bit pricey for me at £4,595.00. Laserscript used to make the same router but smaller (300x300 bed size) for I believe around the £2300 mark which is more realistic to my means. That cheaper router would have probably been my ideal machine was it still made.
    So could anyone please recommend a router with a min bed size of 300x300mm which is capable of cutting: plastics, plywoods and thin brass sheet (2mm brass max) as I used to do on the laserscript router. My max budget is £2500. I am really not against buying used machines.
    thanks for reading and Best wishes,
    Jake Middleton-Metcalfe
    Hi Jake
    Welcome to the forum.
    If i was in your situation i would place a request in the FREELANCE JOBS AND REQUESTS section, there are forum members that will build you a machine to your required spec. don't know if it would be within your budget as the control gear can get a bit costly if you are looking for reliability but it's wortrh a shot.
    Good luck
    Mike
  1. FRO/SSO Potentiometer recommendations?
    By m_c in forum General Electronics
    Last Post: 08-05-2017, 09:08 AM
  2. Recommendations for Z Axis?
    By samsagaz in forum Gantry/Router Machines & Building
    Last Post: 27-07-2016, 12:46 AM
  3. Breakout board recommendations
    By GND in forum General Electronics
    Last Post: 15-07-2015, 07:24 PM
  4. Cutting PCB’s - recommendations, tools etc
    By Fivetide in forum Electronic Project Building
    Last Post: 22-07-2013, 01:23 PM
  5. CNC Lathe recommendations?
    By UltraMagnus in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 07-09-2011, 08:51 PM
