    Trying to make decisions on the way to go, in order to get some experience of 4th axis machining. The capacity of one of the 100mm Chinese harmonic drives would suffice. Or I could convert a Vertex D/head. Anyone have any experience of the Chinese units please.
    Chaz's Avatar
    Also keen to know this as Ill be looking at a 4th axis soon for my new machine.
    I got a 4th axis bundled my 3040 machine. I find that mechanically it's not bad at all bad (reasonable bearings and tailstock) , but it's seriously let down by the puniest stepper I've ever seen and a tommy bar chuck that's really awkward to use insomuch as it's not very well built and runs of true by varying amounts dependant on how much you tighten it. It might be worth a look if you already have a chuck and a stepper kicking about that you can press into service and would definitely well enough for you to get the hang of using 4 axiz on very light duty objects but for me that's about their limit.
    Col.
    Chaz's Avatar
    Quote Originally Posted by Seafax View Post
    Col.
    For me, id remove the stepper and put a servo on. Sorted.
    Thanks for info - Col, could you advise size of the stepper, spec. or dimensions. Also do you have the 100mm chuck.
    I have the 75mm chuck with a nema 23 1.8NM 3 amp stepper.
    Chaz's Avatar
    Quote Originally Posted by Leadhead View Post
    Can you link one of these harmonic drives please?
    Chaz's Avatar
    Great, thanks.
    When can we expect your review?
  1. Harmonic 4th Axis
    By Leadhead in forum General Discussion
    Last Post: 26-08-2015, 04:20 PM
  2. Wanted - Delrin nuts for Chinese 3020 CNC - X and Y axis
    By camhguh in forum Chinese Machines
    Last Post: 24-06-2015, 09:16 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. Replacing motor on small harmonic drive ?
    By fabhund in forum Gantry/Router Machines & Building
    Last Post: 23-12-2014, 12:28 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
