Thread: Chinese Harmonic 4th axis
I got a 4th axis bundled my 3040 machine. I find that mechanically it's not bad at all bad (reasonable bearings and tailstock) , but it's seriously let down by the puniest stepper I've ever seen and a tommy bar chuck that's really awkward to use insomuch as it's not very well built and runs of true by varying amounts dependant on how much you tighten it. It might be worth a look if you already have a chuck and a stepper kicking about that you can press into service and would definitely well enough for you to get the hang of using 4 axiz on very light duty objects but for me that's about their limit.
Col.
09-06-2017 #2
10-06-2017 #3
Thanks for info - Col, could you advise size of the stepper, spec. or dimensions. Also do you have the 100mm chuck.
10-06-2017 #4
I have the 75mm chuck with a nema 23 1.8NM 3 amp stepper.
Harmonic 4th Axis
By Leadhead in forum General DiscussionReplies: 3Last Post: 26-08-2015, 04:20 PM -
Wanted - Delrin nuts for Chinese 3020 CNC - X and Y axis
By camhguh in forum Chinese MachinesReplies: 12Last Post: 24-06-2015, 09:16 PM -
Chinese 6040 from uk eBay seller x axis problem
By CommanderKenyon in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 20-02-2015, 02:13 AM -
Replacing motor on small harmonic drive ?
By fabhund in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-12-2014, 12:28 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
