Thread: MPG Jog interface for Mach3
19-09-2009 #31
Whatever you do DON'T INSTALL THE DRIVERS, that will fluff everything up, all you need is the shuttle plugin off the Mach > Plugin's page.
In Mach go to Config, Config Plug in and if it's loaded it will be there, click Config, right hand side in yellow and make sure you select Shuttle PRO, right hand side at the bottom.John S -
19-09-2009 #32
Dose Mach use different plugins for each model they do John ?
I have not installed the drivers because I remember you telling me not to do this when I first pinched yours.
Already been to the Mach plugin config page and tried shuttle pro, shuttle and all the rest of them, still no joy.
I unplug yours (Johns) which works fine and then closedown mach3, plugin in the new one and I get the message - No shuttle detected for type selected - tried all the different types and restarted mach each time after switching, still no joy.
After lurking around I found this - http://www.machsupport.com/forum/ind....html#msg69461
Seems that I too am the semi-proud owner of a bastard step-child ShuttlePro that is not supported! My VID number is also USB\VID_05F3 as in the machsupport forum post which basically means mach wont find it as it is looking for a VID of USB\\VID_0B33. VID=Vendor Identity
Looks like I need to get a shuttle pro2, or tell John that I have lost his......:whistling:
20-09-2009 #34
No need, I can bloody read................
John S -
20-09-2009 #35
Damn it, sorry steve i wasnt to know mate.
I wonder if we can flash the chip on these or some how right new info to the device so Mach can see it ?Lee
20-09-2009 #36
Just sent ArtSoft an email...
Just got an email from Brian Barker over at Artsoft.
Hello,
I think they do work. If you check out the Machsupport forum I think
you will find some threads where people are using them.
I have not used that Rev so I am no help :(
BrianLee
22-09-2009 #38
Just bought a shuttle express from here -
http://www.enhanceyours.com/media-co...mice-c-86.html
£30 and free delivery!
Good news John, looks like you will be getting yours back! Are you in tomorrow morning? If so get the kettle on, or after taking the piss for "borrowing it" for so long should I bring a flask?
22-09-2009 #39
Bring two flasks...............
.John S -
23-09-2009 #40
lol, ha! ha! Youuurrr in barney rubble !
USB TO Parallel Port DIY Interface
By Lee Roberts in forum Electronic Project BuildingReplies: 42Last Post: 17-02-2018, 07:46 PM -
CIB Industrial Control Interface
By antsals in forum Motor Drivers & ControllersReplies: 8Last Post: 20-04-2011, 11:02 AM -
NEW MEMBER: Cheap DRO using a USB interface
By andyvail in forum New Member IntroductionsReplies: 3Last Post: 17-12-2010, 06:10 PM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
