    I just figured out that one of my drive boards in my Conqueror Design CNC2x box is faulty. Anybody got a spare for sale? The guy at CDE is in hospital and I have no idea when I can get a new one! Any step 1 drive board should do me
    Many Thanks
    David
    Last edited by pistolknight; 12-06-2017 at 09:19 PM. Reason: heading was too specific
    Hi Dave
    If no one has a driver to sell and its going to be a while before
    CDE can supply a replacement
    a photo and data sheet of the faulty board would help
    to identify the stepper driver IC's used to see if its realistic to repair it with minimal tools
    for example
Name:	SLA7062M stepper driver.jpg
    should be easy
    (through hole IC's are easy but surface mount IC's are more of a problem as you may not want to buy the required tools for a one off repair)
    one possibly is to use some thing like a THB6064 stepper driver module
    avoiding the problem tb6560 drivers !!!!!
    John
    Hi John,
    I would use a TB6560 but the problem I have is that the Conqueror card supplies the stepper drivers with a shared direction signal. I have no idea how I can use just the part of the signal that I need for my drive without buying their stepper card interface. Any ideas?
    Best Regards
    David
    Quote Originally Posted by john swift View Post
    Hi Dave
    for example
    should be easy
    John
    Hi Dave
    without photos and the data sheet for the Conqueror driver board
    I can't tell
    not sure of the shared direction signal ?
    should that be shared enable ?
    the only time two drivers have a shared direction signal I know of
    is when two drivers are connected to one axis
    (provided the breakout board can supply enough current )
    John
    Hi John,
    I've not managed to get pictures yet! Work is crazy right now. From what the blurb on the Conqueror Design website says, the drivers are interconnected with a ribbon cable and the direction signal form all the drivers is passed through one wire using a timing sequence. So, my issue is if I use a TB6600 which I have kicking around, how do I get it just the part of the signal intended for that driver?
    David
    Hi Dave
    just looked at Conqueror Design website
    if this is what you have
    going by the width of the ribbon cable that is daisy chained between the driver boards
    I expect all the step and direction signals go to each driver board
    the pictures resolution is not good enough to see but I expect
    each board has links to select the correct signals for that axis
    John
    Yeah that's what I have. According to the information in this link under step1(R4);
    http://www.eaziform.co.uk/files/CNCComps.pdf
    There is only one wire which contains all the direction signals but they are selected at the board. So if I substitute the driver then I somehow need the individual part of the direction signal for that driver
    Any ideas?
    David
    Hi Dave
    if I have read this correctly
Name:	step1 stepper driver   step & dir inputs.jpg
    it looks like for up to 4 drivers
    you can have separate step & direction signals to each driver
    for more axis they must multiplex the direction signals on pin 7
    and store it the appropriate driver board until you need to change that axis direction
    I would need to see the detailed data sheet for a stepper 1 driver board or
    study a board to trace the direction signal path
    I would expect the rest of the circuit to follow the data sheet for the stepper driver IC's used
    John
    I think I'll try wiring up the TB6600 using one of those pins as the direction and see if it works. I remember reading a paragraph in that manual about the timing signal settings but can't find it now
    Hi Dave
    going by what looks like two seperate H bridges on your stepper drivers
    I guess instead of the usual L297 + L298 chip set
    your stepper drivers use a L297 & two L6203 H bridges
Name:	L297  L6203.jpg
    John
  1. FOR SALE: Free - Conect(Conquerer) lathe Board / Cheetah-II drive
    By m_c in forum Items For Sale
    Last Post: 12-07-2019, 09:07 AM
  2. How to wire the enable pin on a stepper drive?
    By cncJim in forum General Electronics
    Last Post: 01-01-2016, 05:10 PM
  3. WANTED: parker CD20 stepper drive
    By drumsticksplinter in forum Items Wanted
    Last Post: 29-03-2014, 03:35 PM
  4. What voltage for stepper drive?
    Last Post: 22-01-2014, 10:49 PM
  5. BOB & Stepper Drive
    By GTJim in forum General Electronics
    Last Post: 22-08-2013, 07:17 PM
