    Yeah that's what I have. According to the information in this link under step1(R4);
    http://www.eaziform.co.uk/files/CNCComps.pdf
    There is only one wire which contains all the direction signals but they are selected at the board. So if I substitute the driver then I somehow need the individual part of the direction signal for that driver
    Any ideas?
    David
    Hi Dave
    if I have read this correctly
Name:	step1 stepper driver   step & dir inputs.jpg
    it looks like for up to 4 drivers
    you can have separate step & direction signals to each driver
    for more axis they must multiplex the direction signals on pin 7
    and store it the appropriate driver board until you need to change that axis direction
    I would need to see the detailed data sheet for a stepper 1 driver board or
    study a board to trace the direction signal path
    I would expect the rest of the circuit to follow the data sheet for the stepper driver IC's used
    John
    I think I'll try wiring up the TB6600 using one of those pins as the direction and see if it works. I remember reading a paragraph in that manual about the timing signal settings but can't find it now
    Hi Dave
    going by what looks like two seperate H bridges on your stepper drivers
    I guess instead of the usual L297 + L298 chip set
    your stepper drivers use a L297 & two L6203 H bridges
Name:	L297  L6203.jpg
    John
    Quote Originally Posted by john swift View Post
    Hi Dave
    John
    Hi John, my two H bridges are both L298N coupled with a PIC 16F87 I/P.
    If it's the H bridges that need replaced that's no big deal but if it's the PIC won't I be up the creek without a paddle? What is actually happening is that when I jog the motor in one direction then stop, then jog in the same direction again, the motor doesn't always go in the right direction.
    David
    Hi Dave
    I'm assuming the board has a L297 driving the two L298 ICs
    they must of connected the two H bridges inside the L298N in parallel to make a higher current bridge
    until CDE are back in business a faulty PIC is a problem
    unless your lucky and the PIC program is not protected so you can copy a working PIC - a bit of a long shot I know
    for now I would swap the faulty drive with a working drive to prove the driver is the problem and not the control board
    changing the switch settings that determines which axis commands the board responds to may be enough instead of physically moving the board – just avoid jogging into an end stop
    with a logic probe you monitor the L297 direction pin to see if its the PIC or L297
    John
    Hi John
    Thanks again for your help. I've swapped the faulty drive for the other which is known to be ok and it is working just fine. If I could just find a CDE X641SC stepper conversion card then I'd be laughing. I'd be able to fit other drivers. I'm really struggling with this but I don't want to harass the guy for the drives if he is in hospital!
  1. FOR SALE: Free - Conect(Conquerer) lathe Board / Cheetah-II drive
    By m_c in forum Items For Sale
    Last Post: 12-07-2019, 09:07 AM
  2. How to wire the enable pin on a stepper drive?
    By cncJim in forum General Electronics
    Last Post: 01-01-2016, 05:10 PM
  3. WANTED: parker CD20 stepper drive
    By drumsticksplinter in forum Items Wanted
    Last Post: 29-03-2014, 03:35 PM
  4. What voltage for stepper drive?
    Last Post: 22-01-2014, 10:49 PM
  5. BOB & Stepper Drive
    By GTJim in forum General Electronics
    Last Post: 22-08-2013, 07:17 PM
