Thread: Mach3 Auto Tool Zero help
Hi can anyone tell me what I'm doing wrong or missing out please.
I’m trying to set up my Auto tool zero in Mach 3, for some reason it’s decided not to function correctly anymore.
When i select the Auto tool zero button the Z axis starts to lower it’s self and stops when it make contact with the tool sensor.
It then raises 10 mm and stops.
When i select the GOTO switch the Z axis only lowers 10 mm and doesn't take into account the sensor thickness.
This is the Script in my VB editor.
'chengdu xhc tec. probe z surface macro
FeedCurrent = GetOemDRO(818) 'Get the current settings, OEM DROs (818)=Feedrate DRO
ZCurrent = GetOemDro(802) 'OEM DROs (802)=Z DRO
GageH = GetOEMDRO(1001) 'OEMDRO(1001)=Gage Block Height
ZNew = ZCurrent - 300 'probe down 20 mm
Code "G90F200" 'slow feed rate to 100 MM/MIN
SetOemDRO(818,200)
Rem Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "G31 Z" &ZNew
While IsMoving()
Sleep(10)
Wend
Call SetDro (2,GageH) 'DRO(2)=Z DRO
FinalMove = GageH + 10
Code "G0 Z" &FinalMove
Code "F" &FeedCurrent 'restore starting feed rate
SetOemDRO(818,FeedCurrent)
Thank you
Kev
11-06-2017 #2
Are you entering the sensor thickness into the gauge height DRO?
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
11-06-2017 #3
Hi Gerry thank you for the reply.
I have tried to enter the sensor thickness in the DRO (Z axis) on the front screen but it cancels out when i select the GOTO button.
I also tried entering it in the VB Script “Call SetDro (2,GageH) 'DRO(2)=Z DRO”
To be honest i don't have a lot of knowledge in the subject
11-06-2017 #4
I've Manged to work out the issue.
The sensor thickness in the Offset colum didn't save the thickness reading.
Thank you
Kev
11-06-2017 #5No.I have tried to enter the sensor thickness in the DRO (Z axis) on the front screen but it cancels out when i select the GOTO button.
The macro is looking in the Gage Height DRO for the sensor thickness. If you don't have it entered there, it's not going to work.Gerry
11-06-2017 #6
hi you can use this
ZNew = ZCurrent - 20 'probe down 20 mm
Code "G90F100" 'slow feed rate to 100 MM/MIN
Code "G31 Z" &ZNew
While IsMoving()
Sleep(10)
Wend
11-06-2017 #7
26-04-2021 #8
If my gauge height is 19.10mm how would the code change as i am unsure where it is entered.
And i will try this code on my machine as i am trying to get a zero z script to work
26-04-2021 #9-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
26-04-2021 #10
Hi dean
long time. i have a code here that is on machine but it gose down and touches then gose up about 50mm then when i remove probe and click goto zero it only moves about 25mm down
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P3" ' this delay gives me time to get from computer to hold probe in place
Code "G90 G31 Z-50 F255" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the exact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2, 19.10) ' change .060 to your plate thickness and then adjust for final accuracy
Sleep 200 'Pause for Dro to update.
Code "G1 Z25 F50" 'put the Z retract height you want here, must be greater than the touch plate thickness
While IsMoving ()
Wend
Code "(Z axis is now zeroed)" 'puts this message in the status bar
Code "F" &CurrentFeed 'Returns to prior feed rate
Else
Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if applicable
End If
If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
End If
If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
Code "G0"
End If
WANTED: Boxford or Denford Lathe Auto Tool Changer
By DagnW in forum Items WantedReplies: 1Last Post: 27-03-2017, 10:45 PM -
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
What Spindle / Auto Tool Changer?
By Chaz in forum Tool & Tooling TechnologyReplies: 11Last Post: 01-08-2013, 10:35 PM -
how to make auto tool changer on mach3
By m.vekariya in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-03-2013, 08:48 PM
