    Hi guys i have a avon 2200 and wont to run mach 3. i have 24v analog servos and wondered what i would take to renew the control panel.
    Lives in East Lothian, United Kingdom. Last Activity: 5 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    For 24V, and analogue servos, you'd need something like a CS-Labs CSMIO-IP/A, or Dynomotion KFlop+Kanalog, to be able to run Mach 3.
    thanks for your help mate do u know were a can get these from uk
    Only the CS-Labs units are available from the UK. Zapp Automation sell them (www.zappautomation.com). Dynomotion controllers are only available direct from Dynomotion in the US.
    However, before you buy anything, you'll need to check what kind of position output you get from the servos. They may use resolvers, which the only modern controller I'm aware of that can be made to work with them, is a Dynomotion Kanalog, however even Dynomotion don't really recommend it. The other options would be to retrofit incremental encoders, or fit new servos/drives.
    I'd also recommend you go through the existing controller/wiring, and work out what inputs/outputs you'll need, so you have a reasonable idea of what's involved before you buy anything.
  1. Replies: 9
    Last Post: 16-04-2017, 06:38 PM
  2. CS-LAB AC-servos + SIMdrive
    By blim in forum Stepper & Servo Motors
    Last Post: 20-02-2017, 12:52 PM
  3. op-amp to drive +/-10V analog servo from old +/-5V controller
    By paulus.v in forum Motor Drivers & Controllers
    Last Post: 14-02-2017, 08:33 PM
  4. Mitsubushi Servos
    By Chaz in forum General Electronics
    Last Post: 24-04-2016, 08:08 PM
  5. Open Source Servos
    By D.C. in forum Open Source Designs & Plans
    Last Post: 07-03-2013, 07:29 PM
