I have taken it apart today to see if I can find any more info. The small 3 jaw chuck is actually on a 5c collet adapter. If you look at the 2nd pic, you can see the "hand tightening" device on the opposite end to the chuck, it has a drawbar fitted and when slackened off a few turns, the chuck can be knocked out. This then leaves the ability to put any of the collets I found in the box in and tightened up by hand. These are the collets I thought were maybe Myford collets but now I'm sure they are 5c. This now leads me to believe it was maybe some sort of mini lathe, maybe a jewellers lathe?
The quest continues
18-06-2017 #2
No it's not its the motorised head off a grinder. Owned a couple but seen loads
John S -
18-06-2017 #3
Yes, I see where you're coming from now, been scouring google images but drawn a blank so far.
18-06-2017 #4
Try searching for motorised wheel head grinder and look under images
John S -
20-06-2017 #5
Big thanks to you John, you were spot on. I have now identified this unit as can be seen here
http://www.jubileemactools.com/websi...Unit-p-99.html
Many thanks mate.
FOR SALE: Mans Pillar Drill... good start to cnc mill project?
By kingcreaky in forum Items For SaleReplies: 0Last Post: 05-06-2017, 08:30 PM -
OK maybe this was too aggressive even for Adaptive Clearing ;)
By Washout in forum Metal Finishing TechniquesReplies: 27Last Post: 07-01-2017, 10:21 PM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM -
Mans bst friend.
By Kai in forum General DiscussionReplies: 5Last Post: 17-04-2011, 12:59 AM
