Imo, you're requirements are very different from the average Mach3/LinuxCNC/UCCNC user. 95% or more of the user base has no need for the specs you're spouting.
Neither Mach3, nor UCCNC, is a replacement for a true industrial control. And they don't claim to be.
I don't really care how many ms feedhold takes. UCCNC stops as soon as you it the button. Whether it's 1ms, or 100ms, you still have to reach for the button, and wait for the machine to decelerate, both of which take a lot longer than your 1ms response.
You could at least mention what you're talking about. Bugs reported to CNC Drive are typically fixed in a few days, usually as fast as 1-2 days.UCCNC has itīs own set of issues, which I cannot properly debate since I do no use it, but are quite well documented by many users.
There are no "issues" that I'm aware of, unless you're talking about missing features.
I don't use a lathe, so I don't care about any of those features.
The machine homes to the nearest step, whether it's at 100Khz or 4Mhz, the machine still homes to the nearest step.
All of these are CS Labs features, not Mach3 features. Mach3 is an open loop control, so glass scale feedback is not even used by Mach3.Who else has 1 ms feedhold ?
4 Mhz threading ?
Glass scale feedback at 4 Mhz ?
4 Mhz homing ?
Hw MPGs with instant feedback, due to 1 ms update loop ?
High-speed servo spindles, with differential signalling, for rigid tapping on mill and lathe ?
24V industrial IO ?
With UCCNC and the MB2 breakout board I'm using, I have instant feedhold. Instant FRO and SO using analog inputs. Instant MPG feedback. Rigid tapping. Differential step/direction, and 24V I/O. For about 1/3 the price of Mach3 and a CS Labs controller.
And with it's superior trajectory planner, I've seen UCCNC run 30% faster, while making more accurate parts than Mach3. At the end of the day, that's what matters to me. Not if the feedhold response is 1ms.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
Is there anybody else seriously using VB to program the G code they need?
By cncgcg in forum Programmers CornerReplies: 12Last Post: 16-11-2015, 10:04 PM -
Can linear scales be used in conjunction with mach 3 software?
By Ady37 in forum General DiscussionReplies: 9Last Post: 13-07-2015, 06:09 PM -
Gerber System 48 with Mach 3 software training required!
By Ahmed in forum Opportunities Available & SoughtReplies: 0Last Post: 07-11-2013, 08:56 PM -
May you please have a look at my program ?
By hoezap in forum Programmers CornerReplies: 2Last Post: 16-02-2013, 11:54 AM -
How do I program my TECO VFD? Help!!
By ArdenHTF in forum General DiscussionReplies: 10Last Post: 08-07-2011, 12:23 PM
