    Not sure. I posted the pinout info in another thread. http://www.mycncuk.com/threads/10842...1052#post91052
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Thanks Gerry, that helps. If I can find the pinouts from the RS232 to USB then I'll knock-up a cable.
    Best regards David
    Quote Originally Posted by Agathon View Post
    Best regards David
    A USB to RS232 adapter is not just a wiring adapter. It has a chip and other electronics, and requires a Windows driver. So while you can make your own RS232 to RJ11 cable, you'll still need to purchase a USB to RS232 adapter.
    Gerry
    Ah, OK - just wasted the last hour knocking up an adapter! Back to the drawing board.
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    You need something like this https://www.amazon.co.uk/USB-RS232-C.../dp/B00077DJIQ or one from Maplin some of these don't work well with 64 bit systems.
    The pin outs on the cable are directed at the DB9 plug not the usb plug.
    Also you just might have a serial header on the mother board of the pc. in this case you won't need the adapter.
    I think I'm using this one, which works fine in Windows 10Pro x64.
    https://www.amazon.com/C2G-Cables-26...s=usb+to+rs232
    Gerry
    I've bought a USB to RS232 converter, installed the software and my machine says it's working as it should. However, when I go to the Leadshine software it won't connect to the port at which the device is located.
    I've also noted that in the hardware profile for my machine that 2 serial ports are listed (although they physically don't exist) and they are both working as they should (whatever that means). They are located at COM1 and 2, but the Leadshine software doesn't recognise them either (which seems reasonable since they don't actually exist!!!).
    I had to install a couple of parallel ports when I first got this machine and seem to remember it being quite difficult to get the machine to recognise them. However, this was the system itself not recognising the hardware. In the case of the USB/RS232 it does see it and declares it to be working as it should.
    I've tried plugging it to different USB sockets which just gives a different location. However the location still not recognised by the Leadshine software.
    Unfortunately, I don't have any other RS232 equipped devices to test the port.
    Any thoughts?
    I can just about find my way round a PC, but having had Macs as my main machines for getting on for 20 years I'm neither impressed with PCs nor adept at overcoming their inadequacies!
  1. PDMX 126 with AM822 drivers and relays.
    By dachopper in forum General Electronics
    Last Post: 15-05-2017, 05:59 PM
  2. Geckodrive G251X / G201X or Leadshine AM822?
    By Agathon in forum Motor Drivers & Controllers
    Last Post: 11-05-2017, 12:20 PM
  3. Controller for 8NM closed loop leadshine drivers
    By Matt81 in forum Motor Drivers & Controllers
    Last Post: 19-06-2014, 09:08 AM
  4. NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
    By jimbocafe in forum New Member Introductions
    Last Post: 19-12-2010, 02:45 PM
  5. Purchased a Taig CNC Micromill from Ebay
    By alan2525 in forum Marketplace Discussion
    Last Post: 16-04-2010, 10:53 AM
