    I think I'm using this one, which works fine in Windows 10Pro x64.
    https://www.amazon.com/C2G-Cables-26...s=usb+to+rs232
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I've bought a USB to RS232 converter, installed the software and my machine says it's working as it should. However, when I go to the Leadshine software it won't connect to the port at which the device is located.
    I've also noted that in the hardware profile for my machine that 2 serial ports are listed (although they physically don't exist) and they are both working as they should (whatever that means). They are located at COM1 and 2, but the Leadshine software doesn't recognise them either (which seems reasonable since they don't actually exist!!!).
    I had to install a couple of parallel ports when I first got this machine and seem to remember it being quite difficult to get the machine to recognise them. However, this was the system itself not recognising the hardware. In the case of the USB/RS232 it does see it and declares it to be working as it should.
    I've tried plugging it to different USB sockets which just gives a different location. However the location still not recognised by the Leadshine software.
    Unfortunately, I don't have any other RS232 equipped devices to test the port.
    Any thoughts?
    I can just about find my way round a PC, but having had Macs as my main machines for getting on for 20 years I'm neither impressed with PCs nor adept at overcoming their inadequacies!
    Lives in East Lothian, United Kingdom. Last Activity: 3 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    COM1&2 are most likely for onboard ports that don't have the required headers connected.
    If you go to Device manager, and select the properties for your USB-RS232 adapter, it should show the COM port number somewhere within the properties (I would tell you exactly where, but I'm on my laptop and don't have any adapters to hand to try). Does that COM port show up within the Leadshine software?
    If it doesn't you may need to close and re-open the Leadshine software so it refreshed the COM port list.
    If it does show, it could be a cable problem.
  1. PDMX 126 with AM822 drivers and relays.
    By dachopper in forum General Electronics
    Last Post: 15-05-2017, 05:59 PM
  2. Geckodrive G251X / G201X or Leadshine AM822?
    By Agathon in forum Motor Drivers & Controllers
    Last Post: 11-05-2017, 12:20 PM
  3. Controller for 8NM closed loop leadshine drivers
    By Matt81 in forum Motor Drivers & Controllers
    Last Post: 19-06-2014, 09:08 AM
  4. NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
    By jimbocafe in forum New Member Introductions
    Last Post: 19-12-2010, 02:45 PM
  5. Purchased a Taig CNC Micromill from Ebay
    By alan2525 in forum Marketplace Discussion
    Last Post: 16-04-2010, 10:53 AM
