Page 1 of 5 123 ... LastLast
    I'm running 3 Leadshine AM822 drivers with 2 at more or less their maximum current (5.86A RMS) and my 36v switch-mode power supply just isn't up to it.
    I've been recommended to buy an unregulated supply of around 60-70v. I'm guessing that a 10A supply will be enough to drive all three motors (the Z axis requires very little power). Can anyone recommend a supplier or a method of construction.
    While I currently have just 3 axes but might want to increase to 5 although the 4th and 5th will need lower power motors.
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Agathon View Post
    Ok I am in Spain after a bit of vino But here is a link http://www.zappautomation.co.uk/ps80...er-supply.html but you could build your own for nearly half the price with bits from Rapid on line. https://www.rapidonline.com/electronic-components
    Thanks Clive - I bet it's hot there!
    I've seen those rectifier/smoothing capacitor boards on most home-built PSUs are they available from eBay and Aliexpress? Not quite sure what to search for.
    Enjoy you holiday!
    David
    Having thought about it, I only need to run 2 of the AM822s from a 60-72v PSU. If they are set at their maximum current what sort of VA do I need from the transformer? I'm guessing this will partly depend on the specification of the smoothing capacitors.
    Enjoy you holiday!
    David
    The boards I think you are referring to are not suitable as they have very small caps on them.
    Have a look at Joe's recent build:
    http://www.mycncuk.com/threads/4513-...-router/page19
    post #373 onwards
    And mine from a while ago:
    http://www.mycncuk.com/threads/6988-routercnc_MK3/page3
    Some links here.
    https://www.rapidonline.com/50a-brid...al-case-519318
    https://www.rapidonline.com/samwha-h...acitor-11-3121
    https://www.rapidonline.com/lcr-ep08...-clamp-11-3004
    This has secondary of 25-25v some people like 24 - 24V
    https://www.rapidonline.com/vigortro...-x-25v-88-0005
    And a vid by Joe. He used 4 caps but three is fine.
    https://www.youtube.com/watch?v=4OoQQg76ar4
    https://www.youtube.com/watch?v=WISDqx-e23M
    Many thanks.
    What do you think about power output. I'm running the 2 AM822s at 5.8A RMS (actually, I think that once I have the interface cable I'll programme the drives to 5.5A RMS (2.8 x 1.96) - but that's splitting hairs) so that's total RMS current of 11.6A. The AM822 manual says that 50-70% of the motor current will be sufficient.
    So 2 x 5.5A = 11.0A. 50-70% = 5.5-7.7A x 70v = 385-539VA. So a 500VA transformer should be OK?
    Does that sound right or should I be working with the AC output voltage of 50v?
    I see that Joe used a massive 750VA transformer.
    Is there a reason you are using just two motors like it is a lathe?
    I run 4 nema 23 on my router without problems and 3 on the mill both with 500va transformers the next one up is 625va.
    Remember that the motors rarely all run at peak current together.
    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 16-07-2024 Has been a member for 9-10 years. Has a total post count of 85. Received thanks 3 times, giving thanks to others 11 times.
    And your calculations should use the AC rather than the DC voltage as the factor into the VA rating - so your figures immediately fall by a factor of 1.4! The DC output is essentially the peak value of the AC voltage, having been rectified and filtered, whereas the VA rating is RMS.
    Hope that helps!
    Graeme
  1. Power supply help
    By Davo242 in forum General Electronics
    Last Post: 07-01-2016, 01:00 AM
  2. Power supply
    By racerbear02 in forum Laser Machines & Building
    Last Post: 13-09-2015, 09:27 AM
  3. FOR SALE: power supply
    Last Post: 14-09-2014, 03:19 PM
  4. Replies: 0
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
