    Quote Originally Posted by Agathon View Post
    That sounds like you're talking about the AC PSU input fuse. You definitely don't want any diodes in that position!
    Have you read the post? The diode is to go across the DC fuse output of the power supply to the drivers to give a circuit for the bemf to be able to be dumped into the caps. in case the fuse blows
    I have been following carefully. Joe mentioned a single "flip down type" fuse holder which I interpreted as possibly being an MCB - his video shows one on the 240vac side. Just wanted to make sure he wasn't confusing the two lots of fuses with disastrous consequences!
    No Prob. But in #39 John show a diagram showing the fuse holder clearly showing the fuse connected to the drive +ve
  4. Quote Originally Posted by Clive S View Post
    Fear not on this occasion I wasn't confused!!
    Hi Agathon
    the circuit from post 34
Name:	power supply output fuses.jpg
    when every thing is working
    the fuse short circuits the diode its connected to
    so the power supplies DC output is connected to the driver
    when a fuse fails power from the DC power supply is blocked
    and now the diode provides a path any for excessive voltage
    generated by the motor to be returned to the power supplies reservoir capacitor(s) and used by any other axis driver
    if the FET's have become short circuit then a large fault current will blow the drivers supply fuse and the motor will be short circuited so no generated current can be returned via the diode
    inside a stepper driver the FET's that form the H bridges
    have built in diodes connected across the drain & source terminals
Name:	H bridge inside a TB6600.jpg
    the diodes form a bridge rectifier that converts the AC voltage generated in a mechanicaly driven motor into DC that adds to the external DC supply that powers the stepper driver
    John
    PS
    as an aside
    one of many DIY hand cranked torches using a stepper motor as a generator
    https://www.eeweb.com/blog/extreme_c...otor-generator
    Yes, I saw that.
    Quote Originally Posted by john swift View Post
    Hi Agathon
    John
    PS
    as an aside
    Sorry about this, I seem to have sowed some confusion about my own clarity. My A-level physics knowledge is a bit rusty but I understand the back emf issue and the role and function of the diodes - excellent and clear explanation though.
  1. Power supply help
    By Davo242 in forum General Electronics
    Last Post: 07-01-2016, 01:00 AM
  2. Power supply
    By racerbear02 in forum Laser Machines & Building
    Last Post: 13-09-2015, 09:27 AM
  3. FOR SALE: power supply
    Last Post: 14-09-2014, 03:19 PM
  4. Replies: 0
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
