    Hi Guys,
    I am building a 4-axis CNC router for wood and aluminium. The 4th axis (B-axis) is the swivel head. This is a build for a friend, who will be mainly routing simple shapes on 3 sides on thin-walled aluminium profiles (see attached example). Although I have 3-axis router experience, I am struggling to find an efficient and easy workflow to do repetitive cuts.
    I'd like a workflow which is easy to setup for my friend, who is not cnc-proficient. The requirements are:
    • Cutting mainly 2-d profiles on 3 sides.
    • The profile is to be mounted on the table and the 3 sides to be routed without repositioning the profile.
    • The CAM should be easy to use. 3D preview is a bonus.
    Creating three, 2D operations (one per side) seems tedious. I am open to use Mach4, Linux CNC or other reasonably priced controller. How is kinematics relevant?
    What is the approach you would take?
    Cheers!
Name:	Profile example.png
  1. Replies: 9
    Last Post: 23-05-2015, 02:07 PM
  2. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  3. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  4. easy cnc 3 axis control board
    By edgas10 in forum Motor Drivers & Controllers
    Last Post: 08-01-2011, 06:14 PM
