Thread: big budget cnc
The Following User Says Thank You to Lee Roberts For This Useful Post:
29-06-2017 #2http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
29-06-2017 #3
29-06-2017 #4
I always think of these as 8*4 machines lol as that's what I mostly would use it for but the ability to do 10*5 would be very useful but only occasionally. If i do build my own I will build it to have a workspace of 3m*1.6m because you never know when you need those extra inches ;) Space is not an issue to me at the moment within reason I could fit 3 of these machines in ;)
This machine would be spot on for what I want, I would then convert what I'm building now into an aluminium machine for cutting molds for vac forming and use the big one for wood only.Last edited by Desertboy; 29-06-2017 at 11:41 AM.
29-06-2017 #5
the frame could i make it out of 50x50x3 mm or do i need to use bigger and heaver steel?
i found this shop in holland i think the price is ok because i need supported rails of 3 meter long
https://www.hardware-cnc.nl/en/shop/...ted-round-rail
29-06-2017 #6
29-06-2017 #7
with frame i mean the base of the machine,
i don't have cad program just sketchup i am a woodworker so for drawing kitchens etc thats good enough but i can draw very accurate in sketchup
29-06-2017 #8
29-06-2017 #9
2 years ago I had to build a punching machine (Hydraulic) for plastic I built it from 3mm box section AND it's not strong enough I have to run it about 1/4 the speed I built it to run to get decent results and I'm punching Polyprop. Any faster and the holes are not accurate! I heat the punchs to 230c as well to reduce stresses using nozzle heaters from injection moulding machines.
I would think a minimum of 7mm would be needed if I wanted to make a steel router.
I was shocked the stresses of punching plastic the aluminium casting we made wasn't strong enough to resist the forces and we had to recast in steel and on the first attempt the steel shrunk too much so we had to recast and grind to fit.
If I had a cnc machine then would have been a lot more fun lol.Last edited by Desertboy; 29-06-2017 at 07:03 PM.
Budget Power Drawbar
By needleworks in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 17-12-2015, 11:36 AM -
BUILD LOG: My Budget CNC Router
By Nealieboyee in forum DIY Router Build LogsReplies: 8Last Post: 14-11-2012, 12:57 PM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Which spindle with a £200 budget?
By fasteddy in forum Marketplace DiscussionReplies: 11Last Post: 29-06-2010, 11:51 AM
