Thread: big budget cnc
Page 8 of 8 FirstFirst ... 678
  1. #71
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Just a question do i need to bolt the machine to the floor ? do i need to put rubber between the bottom of the legs and the floor to have the less vibrations?
    No. No need to bolt the machine to the floor I have mine on castors but when it is in place I lift it off the floor on wooden blocks otherwise it would walk about.
  2. #72
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Like Clive, my machine sits on wooden pads under each of the adjustable feet, which can be lifted to make use of the castors. The plan was to make the machine mobile so I can pull it away from the wall if I needed to work on long lengths of material. Wood or hard rubber (like the commercial adjustable feet) are fine.
  3. #73
    just a question
    the supported round rails ( not hiwin etc)
Name:	Ondersteunde as lager.jpg
    those carts how many kg can they carry , because my gantry is becoming very heavy.
    My rails are the SBR 20
  4. #74
    i got a lot of work done this weekend
    the machine has finaly got the rails mounted and they run very smooth
    the gantry rails mounted
    everything is welded and made grinded for paint
    next weekend i will paint the machine
    then i need to move the machine on its right place level
    mount the r&p, the motor's, drivers etc so a lot of work but i am very happy with the result so far
    a couple of my friends where shocked to see this
  5. The Following User Says Thank You to pet30 For This Useful Post:
  6. #75
    It starts to look very nice. There is something in that metal structures that i like...
    thx
    its still a lot of work but i hope everything will work out very good.
    https://www.cnc4you.co.uk/Stepper-Mo...-4-Axis-Nema23
    is this the best set for the machine?
  8. #77
    there will be a lot of replies that say "68V PSU and AM882 drivers." I agree - you are building a good machine so don't spoil it by using under-powered motors. Those motors themselves would be fine but they will really deliver better performance at a higher voltage and drivers to match.
  9. #78
    SO 68V PSU and AM882 drivers is the better opion then?
    the steppermotor's are they ok and i can mount them directly to the rack&pinion ?
    or do i need to use a gearbox of some sort?
  10. #79
    Well its bean a very long time since i last came here ...
    Shortly after I started working out the CNC machine, I bought a land, bought a wife a year later and married a year later
    and start building a year later.
    Our house is now finished and in the meantime I have been able to finish everything due to the corona crisis and finally had some time to continue working on my cnc.
    The frame of the cnc is built in a steel tube of 80x80x4 and is 3200x1760.
    I have a milling range of 2760x1240.
    it has round supporting guidance and works with R&P system (direct drive). the nema 23 motors are pulled against the rack by a spring.
    the software i use is estlcam with an arduino uno.
    I personally find estlcam a very user-friendly software.
    Now I still had some minor problems including:
    the gear does hit the rack but at some point it slips, what could be the reason?
    If I put the machine home (at a rather low speed) at the x axis it goes to 0 and goes back a bit
    on the other side the other motor (X2) runs very slowly and if the machine is homed then it seems to me that the X2 motor "jumps" back 1 cm. What could be the reason for this?
    if I have the machine home so X0 Y0 Z0 estlcam software says that I sometimes have distance and step loss could this also be due to the gear or the smaller limit switches?
    regards
    Up
  1. Budget Power Drawbar
    By needleworks in forum Milling Machines, Builds & Conversions
    Last Post: 17-12-2015, 11:36 AM
  2. BUILD LOG: My Budget CNC Router
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 14-11-2012, 12:57 PM
  3. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
