Thread: big budget cnc
    Quote Originally Posted by pet30 View Post
    and triangulation trusses in both way's?
    Definitely - the frame has to resist the thrust created by the spindle changing direction in all directions so a good sturdy base is essential. Downwards it needs to resist the weight of the material plus the force of the drill or tool etc, no sagging or spring so again, a good firm base is needed.
    Without triangulation if you use min 80x80x3. Otherwise as others said.
    Forget about "wood" and a "machine" in one sentence, "machine" and "steel" go better.
    You constantly use the word "cheap" but i wonder how much you would charge for a custom kitchen and so in Germany? As i know what we charge here Germans in Spain and they find it relatively cheap. Forget that word, make the machine and start making money.
    You could save yourself a lot of money and time if you buy this but how much it would cost to Germany I'm not sure.
    http://www.ebay.co.uk/itm/Linear-mot...wAAOSwCQZZLelQ
    I see an almost finished gantry when I look at this
    I can not find in posts if sb mentioned it earlier but I think that from Germany this is the best thing he could buy http://www.ebay.es/itm/CNC-Set-20x-1...53.m1438.l2649
    Ok, Not Hiwin. But Cheap, in Germany and supported square rail.
  5. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  6. #5
    thx for the link very interesting
    I have changed the design of the machine a bit
    Everything will be made out of 80x80x4 mm thick steel
    My gantry way's about 50 KG of steel.
    I think the supported rails way about 6.6kg and the Z AX about 10 kg .
    So in total ist about 66.6 kg but maybe take 80 kg just to be sure.
    can i use these motors with a r&p system?
    i was thinking going the mechmate way : they hold the pinion against the rail with a spring.
    the machine is still in design fase so i can change a lot so if u guy's have more advice let me know
    thx
  7. #6
    You could move 60-70 gantry with 2x 3nm nema 23 motor driven at 70VDC, as most people on forum do.
    The motor you show is nema 34, will have more inertia. Ok, looking at the inductance of it its not too bad, i could say its even good. But you will need to drive it at least 110VDC as per its chart, or even better use 230V main power drives, which are much more expensive than AM822.
    for software i would like to use estlcam ist a cad and machine sofware together and very easy in use.
    is there a set of nema 23 that u reccomend or do's it not really matter only that they need to be 3nm?
    What about this set?
    http://www.benl.ebay.be/itm/DE-Free-...cAAOSwiQ9ZR3aF
  1. Budget Power Drawbar
    By needleworks in forum Milling Machines, Builds & Conversions
    Last Post: 17-12-2015, 11:36 AM
  2. BUILD LOG: My Budget CNC Router
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 14-11-2012, 12:57 PM
  3. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
