22-06-2017 #1
22-06-2017 #2
22-06-2017 #3
22-06-2017 #4
22-06-2017 #5
Are those pics any good mate?
22-06-2017 #6
yes
this is good enough to see the ground and 3 switch inputs but not know which input is connected to which printer port terminal via opto-isolators
since the 2 pin stop connector in this picture
will be your E-stop
you only have 4 printer port pins to test to find which 3 are for the X Y Z inputs here
John
PS
this looks like it has the various connectors used in your control box
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1Last edited by john swift; 22-06-2017 at 09:58 PM. Reason: add PS
22-06-2017 #7
well we have been doing some investigation, (my controller is usb not parallel fyi)
I think the axis board is buggered, the x axis works only for a few seconds then stops, but on the screen the marker thingy still moves. I have contacted the ebay seller as to how to resolve this as the etsop button also does nothing at all to either the x,y,z axis the spindle or the software.
Im thinking of buying a planet cnc mk3/4 board? but seems a bit extreme considering this is a brand new machine
22-06-2017 #8
from this view your control box has a printer port connector
other pictures of the inside don't show enough detail to see how the printer port connector is or is not connected to the stepper driver IC's
to be controlled by the USB port there must be a motion controller of some sort hidden under the PCB - possibly a copy of a a planet cnc board
just in case you send the box back for exchange
It will be better not to disassemble it any further
JohnLast edited by john swift; 22-06-2017 at 11:06 PM. Reason: add ref to possible copy of a a planet cnc board
22-06-2017 #9
i agree, I have put the lid back on it. From the reasrch I have done other people who have bought the same machine have tried to use the parallel port with mach 3 but will no luck, they have since used the usb and the usbcnc software. I have sent a message to the seller, im hoping we can come to an arrangement and I buy a genuine planet board as I would of thought that would be the best way forward instead of shipping parts too and frow. Does that sound like a reasonable plan of action? also confused as to why the x-axis isnt playing ball too
Wiring home and limit switches
By Lee Roberts in forum General ElectronicsReplies: 24Last Post: 18-11-2023, 06:14 PM -
Wiring Limit switches to Leadshine MX3660
By thomashomer1986 in forum Motor Drivers & ControllersReplies: 19Last Post: 07-01-2016, 08:05 PM -
Wiring limit switches
By Janste in forum Spindles & Drive MotorsReplies: 4Last Post: 10-02-2015, 10:37 AM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Limit Switches
By Leadhead in forum General ElectronicsReplies: 1Last Post: 16-10-2013, 10:41 AM
