    Hi, the way things are going this may be the shortest membership of MYCNCUK.!!
    Apart from the other issues I'm having the red wire on the Z axis stepper motor plug decided to fall out.It doesn't look as though it was crimped at all? Any suggestions as to how I can remove the pin to reconnect it? I've tried a ground down small instrument screwdriver in the square hole above the pin but so far no luck.
    Hoping for an answer
    Bob S.
ID:	21976   Click image for larger version.
    Hi Bob
    I can not help with the connector they have used
    as a plan "B"
    you could solder the motor wires to the cable
    ( after threading heat shrink sleeving on the motor wires first so you can insulate the joints once the solder has cooled )
    or use the 4 pole molex connectors used in PC's
    they are rated 7A
    and are available from Maplin if you want to buy the locally
    John
    Hi John,
    Thank you for the suggestion. At the moment I am considering returning said machine and do not want to do a permanent repair. I know I have to bend a small tab to release the pin but unlike the female plug the tab on the male plug is hidden from view. Anyway I'll keep trying and see what happens.
    cheers
    Bob
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    It will not of been crimped correctly. A couple wires on my 3020 fell out just trying to get the connectors apart, and a few more came out with just a slight pull.
    It will probably need a release tool with a curve/hook in it to press the release tab.
    Personally, I'd remove all the connectors, and join the wires directly. I used good quality butt crimps on mine.
    Well I eventually managed to release the pin and have reconnected the wire. At the moment I am in two minds whether to return the machine or keep it. If I keep it then I will rewire and upgrade the controller/drivers to something more reliable. Waiting for the vendor to provide a fix? for the noise/vibration from the X axis. Hoping for a satisfactory outcome.
    Thank you both for your advice.
    Bob S.
  1. Stepper motor I.D anyone?
    By Nthkentman in forum Machine Discussion
    Last Post: 11-05-2015, 08:03 AM
  2. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  3. Replies: 1
  4. Stepper motor help.
    By Kammo1 in forum Stepper & Servo Motors
    Last Post: 12-02-2010, 11:11 AM
  5. Stepper motor help
    By Mucky Mike in forum Stepper & Servo Motors
    Last Post: 04-04-2009, 04:25 AM
