Hello!
Im no expert so take my advice with a huge pinch of salt :)
The recommendations for the gantry side plates is usually 20mm thick instead of 15 for aluminium routing.
I do think that you need the extra bearings on Z axis.
The motor strength is fine if the motors have low inductance?
Also I don't know about the strenght about mounting the gantry atop of the ballnut like that.. The side plates should be connected to the plate that has the hiwin bearings..
Im sure you will get more feedback!
Otherwise very nice cadwork :)
BUILD LOG: Aluminum CNC , iD2CNC - SS v.1.0 Build log
By iD2 in forum DIY Router Build LogsReplies: 22Last Post: 27-07-2016, 06:52 PM -
Aluminum finish
By Boyan Silyavski in forum Metal Finishing TechniquesReplies: 3Last Post: 07-09-2014, 07:32 PM -
NEW MEMBER: where to buy aluminum extrusion
By troyboy1 in forum New Member IntroductionsReplies: 3Last Post: 21-07-2014, 01:52 PM -
tool for aluminum on uk
By edgas10 in forum Tool & Tooling TechnologyReplies: 1Last Post: 26-04-2011, 11:23 AM -
Milling aluminum and cooling
By Tonny in forum Swarf & Chip ManagementReplies: 6Last Post: 12-07-2010, 03:48 AM
