im doing another video to show exactly what i mean with the axis
24-06-2017 #2
24-06-2017 #3
I wonder if the stepper driver for the X axis is turned up too high, there's a pot to adjust the current to the driver on the board inside the metal box. When you're trying to only move the X it overloads the motor but when you use X&Y together the power supply can't supply enough current to over load the X.
If there is a pot you must be very careful when you adjust it if you use a metal screwdriver otherwise you can short something out but it's really very easy and nothing to be scared of.
Check this vid out for 3d printers but the principles are the same just bigger motors as you have an all in 1 board with built in steppers.
https://www.youtube.com/watch?v=bItYRMLGoVcLast edited by Desertboy; 24-06-2017 at 09:13 AM.
24-06-2017 #4
dont think you can adjust mine?
Attachment 21982Attachment 21983Attachment 21984Attachment 21985Attachment 21986Attachment 21987
24-06-2017 #5
Try turning the jog rate down (velocity) on the faulty axis
When you move in X it runs at full speed
When you move diagonally it will run at a lower X speed to maintain the same diagonal speed. Clearly this works ok so turning X speed down will do the same and it should then be ok
Obviously this is just to get you working. For some reason the driver or wiring is not happy with the pulse rate required for the X axis velocity you are tuned to.
Do you have an oscilloscope? You can check the pulses and see where the dropout is happening. If not check all terminals are tight and make a good connection .
Also that acceleration rate is very low. This is not related to your problem but that will get annoying when you are trying to get into position
Good video by the way that really helpedLast edited by routercnc; 24-06-2017 at 10:12 AM.
24-06-2017 #6
This may or not help but following on from what has been noted try having a hairdryer set on cold to blow air over the driver chips to see if it is over heating.
24-06-2017 #7
tried the jog speed but no difference
just got the hair dryer out lol
24-06-2017 #8
Hair dryer idea also not success :-(
Knackered DeWalt Router
By Wobblybootie in forum DeWalt RoutersReplies: 6Last Post: 24-10-2020, 12:21 AM -
eBay: Emco vmc 100 milling machine and control unit plus manuals
By Lee Roberts in forum Items On eBay UKReplies: 0Last Post: 15-06-2017, 05:16 PM -
Industrial Machine control drives vunerable to hacker attack
By george uk in forum General DiscussionReplies: 3Last Post: 30-07-2014, 01:08 PM -
FOR SALE: £500 Vertical milling machine on stand, ready for steppers and control system
By petemono in forum Items For SaleReplies: 0Last Post: 06-02-2014, 09:52 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM
