Thread: Spindle funny noise
Are you sure that there is not a birds nest in there
Or is the pump blowing air bubbles through it ?
25-06-2017 #2
I'm going with Clive on this one!
Sounds like something in the water lines to me, air bubbles, drain the spindle down and spin it back up empty and see if the noise has gone, then investigate what if anything has got into or is going on in the cooling lines built into the spindle.
Don't worry you can run it dry for these intermittent tests, obviously dont leave it running dry over night or cutting anything.Lee
26-06-2017 #3
Couple of long shots.
Might be one of the bearings in the spindle is not seated properly and is skipping around. Loctite might sort it but does mean spindle disassembly.
Or electrical connection to spindle is arcing - does this have a plug on the top of the spindle. Take it off and check for arcing / black on the pins. Check the wires are tight into the VFD.
07-02-2018 #4
08-02-2018 #5
If I leave it several months without use my little CNC mill spindle motor will make a similar noise until it warms up if I run it above 5Krpm, it seems to be electro-mechanical noise generated when the motor slips a little too much and the VFD tries to sort it out.
funny noise from steppers.
By Davo242 in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 09-03-2016, 07:31 PM -
800w spindle - noise & controlling remotely
By HankMcSpank in forum Generic Chinese SpindlesReplies: 49Last Post: 17-10-2013, 06:26 PM -
Dell monitor making a funny noise !
By Lee Roberts in forum MonitorsReplies: 1Last Post: 13-09-2013, 12:11 PM -
something quite funny
By johngoodrich in forum Machine DiscussionReplies: 4Last Post: 12-09-2011, 10:48 PM
