Thread: Small CNC Lathe
    Good morning,
    I am in search of a decent CNC lathe. something along the lines of the emco compact 5. Must be single phase. I have cash waiting for the right machine and able to collect within 10 days. the machine must be a runner as i need to put into production straight away. but please show me what you have. if its a project then i may be interested for a future project.
    Regards,
    Elliott Hill
    Chaz's Avatar
    I have an Emco PC 120 that has been retroffited to Mach 3 that I will likely be selling soon. Would this suit?
    Hello. Yes very interested. How soon?. Location?. And ball park figure?
    Regards
    Elliott
    Chaz's Avatar
    Quote Originally Posted by Ba55foreva View Post
    Regards
    Elliott
    Hi, give me a number and Ill call you. Numerous options for timing etc. Am based in Uxbridge / Ickenham - UB108TE, West London. The machine was delivered to me by Landy Man, estimated weight is around 600 kgs, so fairly moveable. Its currently on a set of skids in my garage as I move it around as I need to move stuff.
    Hey. Is it single phase? What's the foot print?
    Chaz's Avatar
    Yep, it runs off single phase. Ill do some measurements tonight however the spec for them is widely available. From memory, around 2m wide, 1.4m high in about a meter deep but that is just from memory.
    Ok. Let me know a ball park price mate.
    Elliott
    Chaz's Avatar
    I found some specs here:-
    https://www.exapro.com/emco-pc-turn-...the-p30607031/
    ISTANCE between centers 236 mm
    Swing over bed 180 mm
    Max Dia. Turning 75 mm
    Carreras X / Z 55/172 mm
    Max. Part length to 121 mm dish
    MAIN SPINDLE
    20.5 mm spindle bore
    Bearing 45 mm dia
    MOTOR HOME
    Asynchronous AC motor 1.9 kW (2.55 hp)
    Speed ​​range 150-4000 rpm
    TRUCKS FORWARD
    Fast forward to 5 m / min.
    COUNTERPOINT
    Racing upper 120 mm
    Cane diameter 35 mm
    ELECTRICAL CONNECTION
    Input voltage 400 v 50/60Hz
    Switching capacity 2.3 kVA
    Up fuse max. 16 A
    Dimensions (mm) 2130 x 1400 support bank x 1650 high
    Weight (with bench support 550 Kg
    Chaz's Avatar
    Elliott
    I'd be looking for around £3k. The 120 is a very good and accurate CNC lathe. European made quality, lots of cutting videos on YouTube showing them working.
    It's got full floodcoolant which I've now managed to get working via Mach3.
    Only niggle I have is the VFD is tempremental, replacement is just over £100, can take this off the asking price if happy with it like this.
    Thanks.
    Chaz's Avatar
    Actually, I did do a short vid sometime ago when doing a quick test part.
  1. WANTED: wanted small cnc lathe
    By terry1956 in forum Items Wanted
    Last Post: 16-02-2016, 04:03 PM
  2. WANTED: Wanted small cnc lathe
    By Hellfire in forum Items Wanted
    Last Post: 09-04-2015, 07:49 PM
  3. RFQ: small lathe job
    By yurtman in forum Projects, Jobs & Requests
    Last Post: 29-12-2014, 10:59 PM
  4. Small lathe AC/DC motors on eBay
    By cristec in forum Marketplace Discussion
    Last Post: 18-11-2012, 06:59 PM
  5. small pen lathe
    By luke11cnc in forum Gantry/Router Machines & Building
    Last Post: 07-12-2011, 01:41 PM
