    Lives in Plymouth, United Kingdom. Last Activity: 11 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    If you've got your head around machine coordinates and work coordinates, that's great. A lot of people struggle at that point! Tool offsets are not really needed a lot of the time. In fact, they are most useful if you are using a toolchanger where each tool will go back in the spindle at the same precise position every time. You set work coordinates by touching off the work in X, Y, and Z as described using a reference tool; then the software can use the preset tool offsets to, in effect, reset the Z work coordinate based on the new tool's projection from the spindle every time you change tools. Like a lot of people, I use a slightly different approach. I use a touchplate to set the Z coordinate for the first tool I am going to use. I run a macro which first touches off the movable touchplate (maybe on the top surface of the work, maybe off the spoil board or bed, depending on what I am using as a reference) and then touches off a fixed touchplate set into the bed. The software stores the difference between the Z coordinates. When I switch to the second (or third, etc) tool, another macro touches the tool off the fixed touchplate and can use the stored offset to, in effect, translate this into referencing off the original surface. Which might have be machined away by this point. It's not quite the same as using tool offsets, but it is more suited to a machine like mine where the tool is held in a collet and I cannot control "stickout" very accurately when I change tools.
    Which brings me to my problem with open source software for CNC as it stands at the moment - the commercial software lets me do these kinds of things very easily, both in terms of writing macros and modifying control screens to add or change functionality. I had a play with grbl a while ago for another project as I needed motion control software that I could get inside and modify reasonably easily and grbl fitted the bill. However, there is a big difference between adding functionality via macros that give direct access to "CNC functionality" and working out how to do that while grubbing about with a C compiler. It's a bit like asking why I should bother with using a database package when I could write the same thing in assembler! Well, that's a bit of an exaggeration but it's a bit like that. The other problem is that I ended up using Universal Gcode Sender to sit between PC and grbl. UGS seemed to be the best option at the time I was looking. While it had some machine control features, it was a bit clumsy to use and somewhat limited. That might have changed by now - I haven't needed to look. The commercial options are much better in this respect. LinuxCNC is a halfway house - pretty much the same functionality as things like Mach3 but a full open-source "product". But you do then need to cart around a PC or similar with you, which is why I was looking at grbl. Maybe RPi is the way to go but my aim at that time was to get something working rather than spend ages researching options. I'm sure that this is a developing area, although I have to say that as the open-source aspect is driven mainly by lower-power machines which make less demand on the control system, it may be that the priorities for development will be different in the same way that a desktop skate-bearing machine with a router as spindle differs from a full-sheet router with 3HP spindle. I'm not knocking the former option BTW - my first CNC router was MDF with skate bearing guides and I used that (with LinuxCNC) for the best part of 5 years.
    I shall continue to watch the open-source area with interest as I'm sure that there will be some useful developments. For example, there is the stmbl open-source hardware development for servo drivers, and there are a lot of creative "amateurs" out there.
    BTW, on the subject of Arduino power - I'm pretty sure that the Uno spec says that it is happy with 7-12V as it has onboard regulation to give 5V for the Atmega chip, etc. I think my Sanguinololu 3D printer controller (that dates me...) uses 12V. I'm in the process of developing an Arduino-based controller for a different kind of machine at the moment, which is why I was looking this up on the Arduino site a couple of nights ago. It may be that the shield does not pass its power to the Arduino purely because its acceptable input voltage range exceeds what is acceptable by the Arduino.
    Not sure the specs but you cannot use 12v inductive sensors on a ramps board directly you need to wire some resistors to drop the voltage as it will fry the arduino so I would err on the side of caution.
    I can believe that - most of the motion control boards have the same limitation. The basic electronics is 5V and won't handle more than that on any digital input. With the Arduino, the digital input pins go direct to the Atmega chip and that is rated at 5V on all inputs. However, the power supply via the Vin pin should be happy with 12V as this goes to a voltage regulator to give 5V for the rest of the board. In fact, if you are not supplying 5V via the USB connector, the recommendation is to run the Arduino on at least 7V as the regulator needs a bit of headroom to work correctly.
    Yeah, the most likely reason is the variable input. While the RAMPS is designed specifically for 12V without modding, this board takes 12-36V so it's not a simple matter stepping down the voltage for the Arduino. Saying that... I've previously bought a whole load of really cheap £0.99 tiny little boards that take 5636V and transforms it into 5V then through a USB socket. These boards are about the size of a postage stamp and do the job. So actually building one into the board wouldn't cost much...
    I think therfore that it's just not been upgraded as both that and SD and screen support should be decently simple for someone with the know-how.
    I really love the open source market in some ways, I'm just not able to contribute to that in any meaningful way... yet. I try to think outside the box and take different approaches with my machines for the sake of expanding the database and share that information where I can though :)
  1. Which cables to shield?
    By andy586 in forum General Electronics
    Last Post: 02-07-2014, 04:33 PM
  2. Any arduino coders here?
    By Mad Professor in forum General Electronics
    Last Post: 25-03-2013, 06:07 PM
  3. CNC Controller with Arduino and Gamepad
    By Christian Knuell in forum Electronic Project Building
    Last Post: 20-10-2012, 10:25 PM
  4. ​DIY arduino CNC 2 axis table
    By ruthharm84 in forum Electronic Project Building
    Last Post: 06-05-2012, 01:54 AM
  5. Replies: 0
