Thread: Arduino CNC Shield Power Routing
I can believe that - most of the motion control boards have the same limitation. The basic electronics is 5V and won't handle more than that on any digital input. With the Arduino, the digital input pins go direct to the Atmega chip and that is rated at 5V on all inputs. However, the power supply via the Vin pin should be happy with 12V as this goes to a voltage regulator to give 5V for the rest of the board. In fact, if you are not supplying 5V via the USB connector, the recommendation is to run the Arduino on at least 7V as the regulator needs a bit of headroom to work correctly.
Which cables to shield?
By andy586 in forum General ElectronicsReplies: 0Last Post: 02-07-2014, 04:33 PM -
Any arduino coders here?
By Mad Professor in forum General ElectronicsReplies: 48Last Post: 25-03-2013, 06:07 PM -
CNC Controller with Arduino and Gamepad
By Christian Knuell in forum Electronic Project BuildingReplies: 2Last Post: 20-10-2012, 10:25 PM -
DIY arduino CNC 2 axis table
By ruthharm84 in forum Electronic Project BuildingReplies: 5Last Post: 06-05-2012, 01:54 AM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM
