    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    It would be helpful to see what's on the disk, as I'd hope it would contain a configuration file.
    How big (in MB!) is everything on the disk? Would it be possible to add all the files on the disk to a ZIP, and upload it somewhere?
    Ultimately you'll need to follow these instructions - https://github.com/gnea/grbl/wiki/Compiling-Grbl
    And then to test if it's successfully flashed to the board, open the terminal within the Arduino software, type and send '$' to see if you get a response as per - https://github.com/gnea/grbl/wiki/Grbl-v1.1-Commands
    Can it flash the arduino?
    http://blog.protoneer.co.nz/quick-gr...e-interpreter/
    If you follow this guide make sure you change the device settings that says mega to 328p (Might be listed as nano, think Uno works fine to)
  1. What desktop cnc
    By fbiiburton in forum Gantry/Router Machines & Building
    Last Post: 28-08-2015, 04:10 PM
  2. 1605/1610 have they sent the wrong ones?
    By kingcreaky in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2013, 09:22 PM
  3. Desktop cnc, HELP
    By Walkz69 in forum Machine Discussion
    Last Post: 25-05-2013, 11:30 AM
  4. CNC Desktop Lathe
    By yadu in forum General Discussion
    Last Post: 16-01-2011, 11:07 AM
  5. Stiff 1610 ballscrews, need help.... asap.
    By ccmarco in forum Lead Screws, Nuts & Supports
    Last Post: 05-12-2010, 10:01 AM
