Page 3 of 18 FirstFirst 1234513 ... LastLast
  1. thats very helpful and exactly what I was aiming for as you have echoed what I watched in a tutorial, but remember this is my first time so even though the theory is there putting it into practice is another matter lol. Hopefully ive not cooked anything, just waiting on further instructions on the advanced addons for this box from planet then I should be able to fire the thing up.
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  2. Managed to get a bit more done tonight. I have decided to install limit switches to help prevent damage and to aid homing. I have decided to put 2 each of the x and y axis and one on the z axis. I have soldered 2 small tails to the switches in NC configuration and crimped a small 2 pin plug for future maintenance/removal
ID:	22090Click image for larger version.
ID:	22091Click image for larger version.
ID:	22092Click image for larger version.
    My build blog:
    Chinese 3020t Build
  3. #23
    Enjoying your thread Ravi, thanks.
  4. The Following User Says Thank You to AndyGuid For This Useful Post:
  5. #24
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by ravihotwok View Post
    First job was to solder the pins to the board for the motor connections and other plugs which in not sure of lol
    Ravi I would re solder (re flow all the motor connections that look and are bad on that board) as they will give you trouble and it si possible that could blow the drives if there is a dry joint. The resistors look a lot better.
    All you need to do is put the iron back on them and when the solder starts to flow with the iron still on apply a bit more solder and the flux will do the rest. I know this may be controversial but full lead solder is a lot easier to use.
  7. ffs!
    No problem clive, will take that board out tonight and do as you say to make sure as the last thing I want is parts burning out, will be doing it around 7pm tonight so will do one re solder and post a pic up to see if its satisfactory before I crack on with the rest mate, be handy if you can keep an eye out pal.
    I appreciate everyone's input :-)
    My build blog:
    Chinese 3020t Build
  8. Cheers Andy mate
    My build blog:
    Chinese 3020t Build
  9. right im at work doing a bit of skiving watching homeland and messing with this control box, I have re soldered the plug connections as advised, pelase have a look and give me your thoughts, don't think I can do much better if I'm honest
    before
ID:	22101Click image for larger version.
    And now after re soldering
ID:	22103Click image for larger version.
ID:	22104Click image for larger version.
ID:	22105Click image for larger version.
    My build blog:
    Chinese 3020t Build
  10. #28
    Ravi They are better but some are not good. It does take practise I think you said you have leaded solder.
    You will have to power it up and see. Remember always apply the solder to the joint (its ok to wet the iron first with solder) It should run and not ball up. What is the wattage of your iron?
  11. i have balled it up deliberately, once I had allowed plenty to go into the terminal i then gently moved the iron in a circular motion to ensure the solder didnt interfere with the next one. Iron is 30watt matey
    My build blog:
    Chinese 3020t Build
  12. #30
    Too much solder, you should be able to see the shape of the parts after they are soldered.
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
